JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications supercharged IS200 hesitating at full throttle
Talisker
11-01-2019, 07:25 AM
4.43 or 4.34? Worth checking because the last time I spoke to him he was setting his boxes to the same value as the original black boxes, which was 4.34V.
Talisker
11-01-2019, 07:25 AM #21
S
11-01-2019, 07:39 AM
I'm not sure actually, now you mention it.
When I order mine ill have him set it to 4.44 the same as yours
S
11-01-2019, 07:39 AM #22
P.Lindblom
11-01-2019, 12:12 PM
Stix44 I've organized a RR day with a local forum and I'm going to run my car with the HKS FCD and again with the Lindblom BB and see what the difference is.
I'd love to see the results. Do you have to pay for each run or can you do a couple of extra runs? If so, I could send you two black boxes that are set to 4.34 (standard) and 4.44. When you've decided which one to use you can just send the other one back. It would be very interesting to compare the two outputs. I've tried to find the voltage level of the actual IS200 fuel cut, but I haven't succeeded.
Talisker 4.43 or 4.34? Worth checking because the last time I spoke to him he was setting his boxes to the same value as the original black boxes, which was 4.34V.
That is correct. I set the BBs to 4.34V, which is the same as the original TTE black box. I can, however, set them to pretty much any value.
Stix44 When I order mine ill have him set it to 4.44 the same as yours
If you want it at 4.44V I'll have to send it on friday instead of tomorrow. I've got it at work and I can only calibrate it at home. If you want me to send two black boxes I can do that on monday as I'd have to make one more Smile
P.Lindblom
11-01-2019, 12:12 PM #23
S
11-01-2019, 01:46 PM
Thanks mate, I've PMd you Smile
S
11-01-2019, 01:46 PM #24
P.Lindblom
13-01-2019, 12:56 AM
Your black box has been recalibrated to 4.44V and it will be on its way in just a few hours.
[Image: img1512p.jpg]
P.Lindblom
13-01-2019, 12:56 AM #25
S
13-01-2019, 01:03 AM
Awesome! I can't wait to get it on the RR and see the results!
S
13-01-2019, 01:03 AM #26
13-01-2019, 01:51 AM
Also keen to see dyno result with the 2 BBs and FCD comparison.
13-01-2019, 01:51 AM #27
P.Lindblom
13-01-2019, 01:56 AM
Stoney Also keen to see dyno result with the 2 BBs and FCD comparison.
So am I Smile
We'll only get the results with the HKS FCD compared to one BB though, the 4.44V one.
P.Lindblom
13-01-2019, 01:56 AM #28
So am I Smile
S
13-01-2019, 02:05 AM
I'd love to do the FCD Vs. 4.34v BB Vs. 4.44v BB but I don't have the money for 3 RR runs!
S
13-01-2019, 02:05 AM #29
164
13-01-2019, 02:34 PM
mine dose the hesitating to! its a dastek chip, it has a flat screw on back is this t adjust the voltage and how would i do it? if not think ill be going for the mk2 BB, set a 4.44v
lookatmybiceps
13-01-2019, 02:34 PM #30
Views 1,773
05-07-2023, 05:08 AM
Last Post by damtrx
Views 828
17-04-2023, 03:51 AM
Views 1,424
05-04-2023, 03:19 AM
Last Post by damtrx
Views 767
01-03-2023, 01:51 PM
Last Post by TheDieselDoctor
Views 306
29-11-2022, 03:38 AM
Last Post by phaebo
Views 402
30-04-2022, 06:27 AM
Views 606
27-04-2022, 12:45 PM
Last Post by oedipus
Views 697
19-06-2021, 12:50 PM
