Hard drives
Hard drives
toxo It'll be graphics card drivers not monitor drivers. I doubt there will be a driver for your TV and even if there is, all it does is list supported resolution & refresh rates (and clock timings and a few other things). This is not applicable with HDMI, DVI or even late VGA connections as they use a thing called DDC to communicate directly with the monitor and interrogate its list of valid resolutions, rather than requiring the driver file.
It may be other power saving related things. Disable them all (hibernate/suspend etc) and see.
Another thought (I'm sure you'd have already checked this) - DVI to HDMI adaptors are pretty bulky and when combined with the weight of an HDMI cable can be a lot to hang off the back of a graphics card. Are all your connections done up tight? I guess you've had the PC out and disconnected everything to install the SSD. I had this with my mum's media PC when she got her HD panel, ended up replacing adaptor + cable with a direct DVI to HDMI cable.
Ok so this is all up and running on the SSD now so put my old hard drive back in and formatted it.
How do I move the user folders on to the hard drive? Is that even possible?
There are a few different ways to do it, none of which are foolproof. You can for example just move 'special' folders such as Documents, Pictures etc. Or you can fool windows into thinking the folder is still on the C: drive when it is infact redirected at a lower level.
See http://www.starkeith.net/coredump/2009/0...her-drive/
The way I did it is just relocate the folder using the 'location' tab.
Just make a new series of folder in the HDD, that goes, USER>"Your Username">and then all the folders like pictures, music, documents, downloads etc.
You then go into your SSD folders, right click on a folder you want to move, go to the 'location' tab and just change the drive letter from C: to whatever your HDD is (in my case, it was H
Then just copy all the documents into their relevant folder.
EDIT: Just looked at the link Toxo posted and it's basically a much more detailed explanation of how to do the method I said. lol
toxo No it's notIt starts with an explanation about why what you've done doesn't always have the desired effect... but is much much easier.
Thanks guys, I knew about just changing folder locations but it's the method Toxo linked about moving the entire user profile that I was thinking about.
Although having a quick skim read of that it does look a bit involved, I'll have to sit down when I'm less tired and read through it carefully to see if it's a good idea to have a go or whether I should just go for the simpler option.
In reality my "My Documents" doesn't usually have that much in it so could really stay on the SSD, it's the "public" folder that's larger so I could just move those folders and leave the rest as is.
May be slightly off topic and probably a stupid question - I await :Overkill: for this:
Why are hard drives built the way they are and not more like SD cards - for example my phone has 32GB on a tiny little micro SD card, why is a PC hard drive so blooming big and well slow by comparison
FirebirdPhil May be slightly off topic and probably a stupid question - I await :Overkill: for this:
FirebirdPhil Why are hard drives built the way they are and not more like SD cards - for example my phone has 32GB on a tiny little micro SD card, why is a PC hard drive so blooming big and well slow by comparison
