JapCarForum General Discussions The JCF Lounge Is it hard to fit parking sensors?
25-03-2017, 12:56 AM
While the Prius is in the bodyshop were thinking of getting parking sensors fitted to the rear but they've quoted £465+VAT Confusedhock:
Not that I was expecting a lot less, but that's still a lot of cash so as many have fitted them themselves wanted to ask if it's not too hard?
25-03-2017, 12:56 AM #1
25-03-2017, 01:10 AM
You can fit these yourself mate.
Most kits have a cutter enclosed to fit the sensors nice and tight.
25-03-2017, 01:10 AM #2
25-03-2017, 01:48 AM
Lexusboy You can fit these yourself mate.
Ok cool, so the principal is technically the same as fitting spotlights in the ceiling? I can do that so this shouldn't be too bad :tongue_smilie:
25-03-2017, 01:48 AM #3
25-03-2017, 02:16 AM
DJ Wozza Just don't buy one of those stick on kits I saw the other day on a Citroen,
the sensors were stick on the outside, with wires coming outta the boot !!
Lol, no chance of me getting those - I find it frightening there are people that are satisfied with that :laugh:
25-03-2017, 02:16 AM #4
25-03-2017, 02:23 AM
DJ Wozza looking at the state of the Citroen they were badly needed... on all four sides !!
Either that or they were making no difference at all :lol:
25-03-2017, 02:23 AM #5
25-03-2017, 02:59 AM
Very straight forward mate dont waste your £$£$....i'll do it for you at that price:tongue_smilie::laugh:
25-03-2017, 02:59 AM #6
dodgydave
25-03-2017, 11:14 AM
Funny you should ask this question as I have just fitted sensors to the rear of mine about a month ago and I have been thinking of doing a bit of a walk through on here.
I did a bit of research before on LOC and found a post by Cous3 (Keith) who I believe is a member on here too.
He bought a kit from Maplins complete with digital display but I wasn't bothered about the display so I sourced a kit with just the bleeper.
I bought the kit off ebay and cost me around £23 including the delivery . I chose this kit because they are sold in a choice of 18 different colours and I thought I might be able to get a colour that was close to mine. If the colour didn't match then I could paint them.
Here's the kit I bought
[Image: 4507809595_950946e688_b.jpg]
[Image: 4508450356_a3de7a878c_b.jpg]
The kit comes complete with 4 sensors, 1 bleeper, the module unit and even a cutter to drill the right size hole in the bumper.
When the kit arrived it was quite obvious that the colour wasn't going to match so I had to spray them up. A couple of colour coats of paint bought from my local Toyota dealer followed by a coat of clear lacquer which I got from halfords.
[Image: 4508446062_4518598904_b.jpg]
[Image: 4508448252_a9cdb348c0_b.jpg]
As you can see I just used a bit of card with holes in to support the sensors while spraying.
First job was to remove the boot lining around the offside rear light and the boot floor cover.
I measured where I wanted the Sensors, approx 22cm up from the groove near the bottom of the bumper (Don't measure from the ground, especially if you are parked at ther side of the road on a camber!) and approx 41cm between the Sensors. I also used the boot latch as a guide to the centre of the bumper. I placed masking tape on the bumper in the correct places and marked with cross hairs.
[Image: 4507815347_6eb27d9bb7_b.jpg]
Once I was happy with the positions I had to remove the bumper to drill the holes and feed the cables behind.
I found a good walk through on removing the rear bumper on my.is site here http://my.is/forums/f68/is300-rear-bumpe...al-341081/
Of cause this is on an American IS300 so ignore bit about the side markers.
Once the bumper was off I took it into the garage to drill and fit the sensors.
[Image: 4507817323_22b411692a_b.jpg]
Just take it very slowly and dont push too hard as when the drill bit gets through you may damage your paintwork.
Next job was to tape all the sensors wires together and run them along to the offside of the car were they will be run up behind the offside rear light and enter into the boot space through the same rubber grommet that the rear light cable comes through. I didn't take any pictures of this but in the next photo you can see the where to put the cable through where the bulbs are hanging down.
[Image: 4507817637_c02a1f75b4_b.jpg]
After re-fitting the bumper it was time to mount the central control unit and connect the supply wires into the rear light wiring loom. I mounted the control unit in the well under the boot floor using the sticky pad provided in the kit as you can see.
[Image: 4507811733_2c53318098_b.jpg]
Then I made the 2 connections from the Control Box to the Reversing Light (Live & Earth) with Scotchlock connectors and taped them up securely. Red from the Control Box goes to the Red/Blue wire in the OEM Harness, and the Black wire from the Control Box goes to the White/Black in the OEM Harness.
I made this connection just before the connector block for the rear light.
[Image: 4508452598_8db3a1732a_b.jpg]
Next I mounted the bleeper using the sticky pad provided up just under the rear shelf. I first tried every thing out to see if the bleeper was loud enough to hear inside the car and found that it is.
[Image: 4507814019_aa8c396b75_b.jpg]
So all I had to do now was put all the panels back in the boot and stand back and admire.
[Image: 4508457432_c486857f08_b.jpg]
[Image: 4508457642_061136f574_b.jpg]
Having had these fitted now for about month I am over the moon with them.
When you first go into reverse you hear one bleep from the bleeper, just to let you know that the system is working, then as you reverse towards an obstruction you start to hear a bleep at about 1 per second at about 1.5m. When you are about 90cm the bleep is about 2 per second and at about 40cm it's continuous; you should stop now.
All together I suppose it took me a couple of hours to fit not including spraying the sensors.
Hope this helps and thanks to Cous3 for his original post on LOC.
Dave
dodgydave
25-03-2017, 11:14 AM #7
Dave
25-03-2017, 11:22 AM
That's a great walkthrough mate, thanks for that! (rep added)
Maybe one of the mods could separate this into a new thread as this could be useful for anyone doing this Smile
25-03-2017, 11:22 AM #8
dodgydave
25-03-2017, 11:25 AM
Marsdendean Think you should help people at meets to do them! Wish i had something like this on mine, and will look into it since it was only £23 !!
I wouldn't mind at all helping someone at a meet it really is a very simple job and as they say 'many hands make light work'.
dodgydave
25-03-2017, 11:25 AM #9
25-03-2017, 12:52 PM
parthiban That's a great walkthrough mate, thanks for that! (rep added)
agreed, dave why don't you copy your posts into a new thread, nice work mate!
25-03-2017, 12:52 PM #10
Views 1,357
06-05-2019, 03:27 AM
Replies 22
Views 784
06-09-2018, 12:18 PM
Views 527
16-08-2018, 02:38 PM
Views 215
16-08-2018, 09:52 AM
Last Post by leztec
Views 513
19-05-2018, 01:52 PM
Last Post by Stoney
Views 386
17-01-2018, 12:49 PM
Last Post by Tango
Views 615
21-06-2017, 12:03 AM
Last Post by Carpediem
Views 557
08-04-2017, 12:46 AM
Views 478
20-03-2017, 03:49 AM
Last Post by lexynik
Views 273
26-01-2017, 04:16 AM
Last Post by Mikey
