Pages (17): Previous 1 2 3 4 5 617 Next
Daniel N
10-04-2021, 12:25 PM
#31
I'm just waiting for my 145mm pulley in the mail. I will be running the yellow 2ZZ-GE injectors which I already have. I also have the blackbox from Patrik. I'm just a bit confused if I should buy an AFR gauge to measure the air-fuel mixture to be sure.
Daniel N
10-04-2021, 12:25 PM #31
10-04-2021, 02:49 PM
#32
A wideband Afr is vital mate, should be first on the list
10-04-2021, 02:49 PM #32
Daniel N
10-04-2021, 02:59 PM
#33
Ok thanks, could you recommend one?
Daniel N
10-04-2021, 02:59 PM #33
10-04-2021, 07:58 PM
#34
I have an aem one, will be for sale soon as ive bought a stack one, just to match my stack boost gauge lol
10-04-2021, 07:58 PM #34
Ste176
11-04-2021, 03:46 AM
#35
Stav, if he doesn't want it. Ill take that off your hands no problem Smile
Ste176
11-04-2021, 03:46 AM #35
11-04-2021, 07:18 AM
#36
No problem. It's had some messing with the wiring but is in full working order.
11-04-2021, 07:18 AM #36
Ste176
11-04-2021, 01:01 PM
#37
Meh, as long as it works ill be happy enough Smile
Ste176
11-04-2021, 01:01 PM #37
phaebo
12-04-2021, 01:05 PM
#38
arent the 2zz injectors too big for the oem ECU? i heard some people say that 260cc injectors are the biggest injectors the oem ecu will run with? Correct me if i am wrong.
phaebo
12-04-2021, 01:05 PM #38
S
12-04-2021, 05:45 PM
#39
phaebo arent the 2zz injectors too big for the oem ECU? i heard some people say that 260cc injectors are the biggest injectors the oem ecu will run with? Correct me if i am wrong.
No idea, I think lots of people have used 2zz with success - I don't know with what management.
I can tell you the standard ECU can't handle 650cc though.
S
12-04-2021, 05:45 PM #39
Daniel N
23-04-2021, 05:03 PM
#40
The guy from Euro LOC who I bought my 145mm pulley from, said that he had been running 2ZZ-GE injectors with 145mm and a HKS fuel cut defender for about 2 years with no problems.
I now have all the parts exept an AFR. Does anyone know if there's an AFR that uses the existing O2 sensors so I only have to wire the AFR to them?
Daniel N
23-04-2021, 05:03 PM #40
Views 846
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 327
01-07-2023, 06:27 PM
Last Post by lexusdaydreaming
Views 555
14-09-2022, 01:32 PM
Last Post by P.Lindblom
Views 776
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 452
26-07-2022, 05:09 PM
Last Post by reganlives
Views 488
30-03-2022, 09:15 PM
Views 429
13-03-2022, 11:27 PM
Last Post by deccie22
Views 693
17-09-2021, 09:42 PM
Last Post by gsitlv
