JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning is200 centre armrest...all done for £10
IanS200
18-07-2018, 05:42 AM
#31
sorry i havent been able to take any pics due to ending up in hospital to have op on my knee.
can try to explain without pics though
firstly remove centre console with cubby and lid.
remove lid from cubby hole.
turn over and remove 6 screws which hold ashtray and storage box.
this info can be found on this site or google bahamut cars is200.
Next push exposed end of armrest into the bottom of storage box you have just removed, this will leave marks from lugs on bottom of armrest,remove enough plastic with a knife ect so the lugs fit through hole.
Once you have done this you need a piece of metal rod slightly wider than the storage box.
Mark both sides of box just above the curve of armrest mounting bracket,drill a hole either side and a matching hole in centre console you have removed on one side only.
re-assemble centre console without armrest inserted and re-fit to car.
finally push armrest into storage box again,then you need to insert rod through hole in centre console a push through all the way until it holds armrest in place,you can add 2 self tapping screws in the mounting bracket as well if you wish.
Hope this makes sense, if not drop me a pm
Regards Ian.
IanS200
18-07-2018, 05:42 AM #31
Regards Ian.
18-07-2018, 06:48 AM
#32
Moley has a walkthrough posted that shows how to fit an OEM arm rest; it might help the the initial steps getting to the point of fitting...
18-07-2018, 06:48 AM #32
IanS200
18-07-2018, 06:59 AM
#33
DaveEdin Moley has a walkthrough posted that shows how to fit an OEM arm rest; it might help the the initial steps getting to the point of fitting...
Thanks for the link Dave.
IanS200
18-07-2018, 06:59 AM #33
22-07-2018, 06:39 AM
#34
IanS200 Once you have done this you need a piece of metal rod slightly wider than the storage box.
Regards Ian.
Makes perfect sense, so much so that I've just gone and done it :w00t:
Rough fit for now but you get the idea :thumbup1:
[Image: IMG_20110902_160101.jpg]
Toyota Altezza Z Edition.
22-07-2018, 06:39 AM #34
Regards Ian.
IanS200
22-07-2018, 07:56 AM
#35
todd Makes perfect sense, so much so that I've just gone and done it :w00t:
well done fella,looks good.:kiltsmilie:
IanS200
22-07-2018, 07:56 AM #35
22-07-2018, 09:01 AM
#36
looks good mate must get on and do this one myself
22-07-2018, 09:01 AM #36
22-07-2018, 09:03 AM
#37
For a tenner it is the best mod I've ever done, big thanks to op.
22-07-2018, 09:03 AM #37
22-07-2018, 09:07 AM
#38
typical just been on ebay and cant find one
22-07-2018, 09:07 AM #38
IanS200
22-07-2018, 11:32 AM
#39
Lexuspat typical just been on ebay and cant find one
found my latest one at local scrapyard for £5, removed centre console and found 4 £1 coins, so only cost me a quid,......result.
IanS200
22-07-2018, 11:32 AM #39
IanS200
22-07-2018, 11:33 AM
#40
one here mate.
http://www.ebay.co.uk/itm/Stilo-01-07-Fr...1466wt_905
IanS200
22-07-2018, 11:33 AM #40
one here mate.
Views 252
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 928
28-05-2023, 02:46 PM
Last Post by bigdave1701
Replies 47
Views 3,023
08-12-2022, 09:37 AM
Views 283
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 737
23-03-2021, 07:29 AM
Last Post by kaykay
Views 336
15-09-2020, 02:23 PM
Replies 31
Views 1,825
25-07-2020, 07:50 AM
Replies 103
Views 5,815
31-03-2020, 07:02 AM
Last Post by Barry
Views 355
30-10-2019, 05:26 AM
