Pages (76): Previous 139 40 41 42 4376 Next
russelllinn
21-04-2017, 01:23 PM
Confusedhock: that is a strong HG if that happens!! i wait to hear the news, from the sounds of it as you said though as it was only in the breather it will be condensation or water ingress there only!!
[Image: AliceTrack-1.jpg]
Have a look at my Scooby project thread here
My garage
Subaru
russelllinn
21-04-2017, 01:23 PM #401
My garage
Subaru
Fozzy
29-04-2017, 12:24 AM
Mayo in the catch can is normal. The hot oil vapour traveks out there and cools. This will always create condensation, so when they mix you will get the mayo. I try to make a point of removing all oil breather pipes once a year and giving them a good clean through.
Good work on the dizzy cap, i thought it was fiddly in my bay, ive got tons more room than you! Shame it hasnt solved the idleing issues. Have you tried the idle valve on the throttle body. Mine idled beautifully after i gave it a good clean out
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
29-04-2017, 12:24 AM #402
04-05-2017, 07:29 AM
The levels of mayo I had weren't, the pipe was pretty much blocked :lol:
ICV is clean as a whistle. TPS was a bit wrong (idle switch wasn't engaging) but it's still not quite right.
There's something else weird going on now too, get a strange rattling when engaging or disengaging the clutch. Release bearing I wonder...
Also wore my 2 rear tyres through to the canvas while I was in France lol
However it did France and back without breaking so whatever it is it can't be that terminal right?
04-05-2017, 07:29 AM #403
Fozzy
05-05-2017, 12:30 AM
Hmmm got some strange goings on there then. The rattle certainly does sound like release bearing. Thats got to be a tough job. Is it engine out, or can the box be split leaving the engine in?
I guess you had a good Le Mans trip then! Two tyres, not bad going.
Have you checked the coolant temp sensor? this can affect idle and low rpm fueling
Fozzy
05-05-2017, 12:30 AM #404
05-05-2017, 12:38 AM
Box can come out without dropping engine, it's been done twice in the last 18 months...
Yeah the trip was good other than my camera dying!
ECU coolant temp sensor was replaced about 6000 miles ago, cause it was fooked. Next stop ignition coil. Got no money left after the holiday though so it will have to wait until July.
Oh yeah I've fecked my front bumper again too Sad
05-05-2017, 12:38 AM #405
Fozzy
05-05-2017, 12:43 AM
Again, maybe you should be sticking a standard one back on it!
Hmmm im starting to run out of ideas. If coil doesnt fix it then what? youve replaced the majority of components now
Fozzy
05-05-2017, 12:43 AM #406
05-05-2017, 12:50 AM
Well if that doesn't fix it then I guess the spark system is OK, so I'll rip the injectors out, get them cleaned & balanced, replace the fuel filter. If that's all OK then I'll rip all the intake tract off (manifold back) and clean it all out. Still need to get the mechanical timing checked out as well.
If it's still fooked after that then it needs a head rebuild or something more serious and I'm not doing that :lol:
05-05-2017, 12:50 AM #407
Fozzy
05-05-2017, 12:55 AM
That all sounds like so much fun. I dont envy you one bit. Saying that, when was the fuel filter last changed. It often gets forgotten about come service time
Fozzy
05-05-2017, 12:55 AM #408
05-05-2017, 01:08 AM
I changed it erm... year and a half ago maybe? Could be coming up 2 years though.
05-05-2017, 01:08 AM #409
05-05-2017, 03:20 AM
These turned up the day I was leaving for France:
[Image: nuts.jpg]
I had to take them to France and fit them at the campsite, that's how pushed for time I was!
Before photo, you can't really see the state of the old nuts here. They were chrome once but the chrome had all flaked off, leaving rust. They'd also got quite soft and were misshapen, so it was difficult to get a socket onto them.
[Image: before.jpg]
Shiny new JDM RAYS nuts:
[Image: after.jpg]
Flaky chrome, rusty, non-locking wheel nuts replaced with nice gunmetal lockers, that I actually have the right size socket for (I think this is what did for the old nuts).
05-05-2017, 03:20 AM #410
[Image: nuts.jpg]
[Image: before.jpg]
[Image: after.jpg]
 4 Guest(s)
 4 Guest(s)
Views 873
31-10-2023, 10:05 PM
Views 1,458
08-10-2023, 03:59 AM
Views 5,923
06-10-2023, 02:58 AM
Views 3,084
04-10-2023, 03:52 PM
Views 21,930
10-09-2023, 07:50 PM
Replies 79
Views 4,220
03-09-2023, 10:30 AM
Views 1,921
17-05-2023, 11:25 AM
Views 6,360
05-05-2023, 01:09 PM
Views 855
18-03-2023, 01:09 PM
