JapCarForum Cars, Cars, Cars! Project Cars Mazda MX5 Turbo
Mazda MX5 Turbo
Mazda MX5 Turbo
hoodedreeper
25-03-2020, 01:45 PM
#41
I know exactly how you feel John. There was numerous times where things just werent going right and could have given up and sold it all. But ive very very glad i didnt! Just walk away,have a cuppa and try again,always works Smile
hoodedreeper
25-03-2020, 01:45 PM #41
hoodedreeper
27-03-2020, 01:26 PM
#42
I joined the MX5OC on a drive Sunday across the Suffolk Country Roads,and its the best day of driving i've ever had! The car performed extremely well and even had the company of my mapper Lawrence in the convoy in his boosted MX5!
I've got a couple of videos from the drive,but due to the length/size of the videos they take forever to upload Sad Here are some photos from the day. The rest of the photos can be found on my Photography page on Facebook https://www.facebook.com/media/set/?set=...756&type=1
[Image: 8715828194_3e198eb304_z.jpg]
[Image: 8714707997_c132b8dfd1_z.jpg]
[Image: 8715828130_af2318986b_z.jpg]
[Image: 8715827860_d0fc71bcf8_z.jpg]
[Image: 8714706913_4caea7d4aa_z.jpg]
[Image: 8714706837_eda326cb9a_z.jpg]
[Image: 8715825284_fa0afd6498_z.jpg]
Took the car to H&S Performance today to get a few bits fitted.
Underseals and my P5 Frame Rails fitted
[Image: 8721792940_6cc6a5dbe7_z.jpg]
[Image: 8721792840_aa5f7b0a85_z.jpg]
[Image: 8720671043_5b3cdb1e4c_z.jpg]
O/S Rear Inner Arch hole
[Image: 8720671469_b5060df2bd_z.jpg]
Repaired/Welded
[Image: 8720671449_80d38e4039_z.jpg]
Mocal 13 Row Oil Cooler w/ Thermostatic Sandwich Plate
[Image: 8721792664_c56bda481b_z.jpg]
[Image: 8721792332_046871b2ba_z.jpg]
[Image: 8720670957_c448fdc25e_z.jpg]
Wrinkle Black Inlet Manifold fitted
[Image: 8720670749_0d5de33d9b_z.jpg]
[Image: 8720671177_b607169d41_z.jpg]
Apologies for the photo quality,had to use my phone.
Heres another test video of the External Mic on the GoPro. This time its on the rear bumper next to the exhaust
http://www.youtube.com/watch?v=wIVMVy1YafY
hoodedreeper
27-03-2020, 01:26 PM #42
Repaired/Welded
31-03-2020, 10:11 AM
#43
looking good
31-03-2020, 10:11 AM #43
looking good
hoodedreeper
31-03-2020, 12:34 PM
#44
Just put this together,the evolution of my MX5 in the nearly 2 years of ownership
[Image: 8732102129_fdec8808e9_k.jpg]
hoodedreeper
31-03-2020, 12:34 PM #44
john wan
21-03-2021, 11:31 AM
#45
Hi mate ive got a friend whos starting a turbo conversion on his mx 1,6 hes looking where to get the oil flow from you got any pictures of yours?
john wan
21-03-2021, 11:31 AM #45
Mr Reman
21-03-2021, 12:15 PM
#46
My MX5 was a 1.8 so I didn't look too heavily at turboing 1.6's, But I seem to remember that early Mk1 MX5's had a pre drilled/tapped oil take off machined into the block that were plugged with a bolt (Some sort of design throw back to the "B6T" and "BPT" turbo engines).
It's been a few years since I've even thought about anything MX5 related, So I can't say for certain where this blanked off oil take off could be (Strange feeling that it's somewhere below the rear exhaust port) or what year would be the cut off point between an engine having this or not.
I know that a lot of people just added an oil filter relocation kit when they turboed them because it gave them an easy way to cut into the oil supply, AND it stopped oil filter changes being such a bi*ch of a job, But this option did lead to quite a long oil feed pipe.
Reman.
Air filter by K+N, Exhaust by Japspeed, Brakes by Mintex......... And a scuffed rear arch by my sister. Huh
Mr Reman
21-03-2021, 12:15 PM #46
Reman.
john wan
21-03-2021, 09:25 PM
#47
Yeah seen on tinternet that theres a bolt bot not on his hes saying its got a bit on the block that looks like it was molded to have a bolt there but no hole if that makes sense
john wan
21-03-2021, 09:25 PM #47
Mr Reman
21-03-2021, 09:36 PM
#48
I've just wondered if there would be a high enough flow rate from the hole the oil pressure sensor screws into? I don't know how feasible it would be, But could a "T" adapter go into there to allow the sender to still screw in, and also flow enough oil to the turbo?
Anyone got any thoughts on this?
Mr Reman
21-03-2021, 09:36 PM #48
john wan
21-03-2021, 09:42 PM
#49
Yeah when I googled for him lastnight I see some one had done that means a long feed pipe eh
Edited 03-05-2014, 07:17 AM by john wan.
john wan
21-03-2021, 09:42 PM #49
Mr Reman
21-03-2021, 10:54 PM
#50
Could go propper hard core and fit a separate oil system. Smile
Something like a 200SX diff cooler setup might work, And it would mean that he could run a litre of nice turbo friendly oil in a closed system that's separate from the engines mineral oil and any of the microscopic alloy and cast iron particles that would be floating about in it close to service time. It would also mean not having to shell out 40 or 50 notes for a full 5 or 6 litres of decent synthetic stuff every oil change as it would only need the litre or so in the expensive oil in it's own little header tank changing (And the usual high quality mineral oil in the engined sump).
The electric pump could be setup with a timer to keep the turbos oil flowing for a couple of minutes after the engines shut off too.
It's just an idea that kept popping into my head back in my MX5 days, But I can't see why it wouldn't work.
Reman.
Mr Reman
21-03-2021, 10:54 PM #50
Reman.
Views 77,537
08-02-2024, 01:53 AM
Replies 23
Views 1,683
04-01-2023, 03:30 PM
Last Post by aaron1991ellis
Replies 65
Views 5,431
21-12-2022, 09:37 AM
Last Post by jeffrosie
Replies 179
Views 15,528
17-12-2022, 10:34 AM
Last Post by phaebo
Replies 39
Views 4,353
13-12-2022, 01:00 PM
Last Post by N15_GTi
Replies 69
Views 13,518
25-11-2022, 04:48 AM
Views 802
03-09-2022, 10:44 AM
Views 3,692
30-07-2022, 06:45 PM
Last Post by Lexus RS200T
Replies 38
Views 4,136
18-06-2022, 08:37 AM
Last Post by Lerch
Replies 1,318
Views 95,953
05-06-2022, 08:23 AM
Last Post by sarah0
