Pages (17): Previous 13 4 5 6 717 Next
phaebo
23-04-2021, 05:20 PM
#41
Oow so then i think you could also use the patricks blackbox with he 2zzge injectors and 145 mm pulley.
I dont think an air full ratio meter with the existing o2 sensors will give good numbers. It only gives you an indication of runnign lean or rich.
You better use an air full ratio meter with a wide band o2 sensor those will give much more accurate numbers
phaebo
23-04-2021, 05:20 PM #41
23-04-2021, 05:50 PM
#42
+1 for the wideband sensor.
And yes you are better off using Patriks Black Box as they give a much smoother fuel supply.
23-04-2021, 05:50 PM #42
Daniel N
23-04-2021, 06:48 PM
#43
I am using Patriks box :wink:
Ok so with an wideband AFR should I then unmount an existing O2 sensor or drill a new hole in the exhaust and make a thread?
Daniel N
23-04-2021, 06:48 PM #43
23-04-2021, 06:57 PM
#44
Personally I'd weld a new bung on for the wideband. You actually get one inthe box with a new aem Afr gauge
23-04-2021, 06:57 PM #44
Daniel N
23-04-2021, 07:02 PM
#45
Ok great.
Where should the wideband be mounted? Just before the cat?
Daniel N
23-04-2021, 07:02 PM #45
Ok great.
phaebo
24-04-2021, 04:07 AM
#46
Exactly !
phaebo
24-04-2021, 04:07 AM #46
Exactly !
Daniel N
04-05-2021, 11:02 AM
#47
Hi guys.
My setup will be:
TTE supercharger kit
Bigger pulley 145mm
2ZZ-GE yellow injectors
Black box from Patrik
I was going to buy the AEM gauge with wideband sensor for safety, but then I thought about GREDDY E-MANAGE ULTIMATE and then get the car mapped at a dyno. Will it be worth it or should I stick with just the AEM wideband?
Daniel N
04-05-2021, 11:02 AM #47
Hi guys.
My setup will be:
Bigger pulley 145mm
04-05-2021, 12:05 PM
#48
Pretty sure you need it remapped if you change the injectors. So you'll need the emanage
04-05-2021, 12:05 PM #48
04-05-2021, 01:04 PM
#49
I agree with Stav, better get an e-manage and have a good map
04-05-2021, 01:04 PM #49
phaebo
04-05-2021, 04:37 PM
#50
My setup is almost the same right now. I use a 145mm pulley with bigger intercooler patricks blackbox and 1zz fe injectors.
I can say that it runs very smooth and pulls very strong compared to the standard setup with 130 mm pulley. I am now boosting 7 psi just before the rev limit.
I am now looking for a aem gauge with width band sensor. But compared to your setup i am very interested to see wich injector setup is better. Because my car is allready running very sweet now but not sur about the air fuel ratio. So i might also need the 2 zzge injectors.
Let us know how it is running when al the things are installed
phaebo
04-05-2021, 04:37 PM #50
Views 841
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 327
01-07-2023, 06:27 PM
Last Post by lexusdaydreaming
Views 555
14-09-2022, 01:32 PM
Last Post by P.Lindblom
Views 776
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 452
26-07-2022, 05:09 PM
Last Post by reganlives
Views 488
30-03-2022, 09:15 PM
Views 429
13-03-2022, 11:27 PM
Last Post by deccie22
Views 693
17-09-2021, 09:42 PM
Last Post by gsitlv
