JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security widnes_is200's headrest screen walkthrough
26-01-2018, 07:42 AM
#41
How do you get the backing of the seat apart or did you not need to? Can a coat hanger be used to feed the monitor cable through the back of the seat. I had a quick look the other day, did you remove the little metal rings at the bottom of the seat? Also where did you route your cables? Ive got the power leads coming through the centre console from the head unit loom and will ground it on the ciggie lighter, not sure what the best way is to get them to back up into the seat from there?
26-01-2018, 07:42 AM #41
aaronabbott
26-01-2018, 08:44 AM
#42
SHAHZ How do you get the backing of the seat apart or did you not need to? Can a coat hanger be used to feed the monitor cable through the back of the seat. I had a quick look the other day, did you remove the little metal rings at the bottom of the seat? Also where did you route your cables? Ive got the power leads coming through the centre console from the head unit loom and will ground it on the ciggie lighter, not sure what the best way is to get them to back up into the seat from there?
my cables run from the heat unit and down through the center console then just out the back of it and straight up into the back of the seat(with a coat hanger or stiff wire with a bit of wiggling it will come out the bottom),so you can only probably see 1-2 inch of the power cable
[Image: photo-40.jpg]
[Image: photo-45.jpg]
[Image: photo-41.jpg]
[Image: photo-42.jpg]
[Image: photo-43.jpg]
[Image: photo-44.jpg]
Edited 09-03-2010, 12:43 PM by aaronabbott.
aaronabbott
26-01-2018, 08:44 AM #42
26-01-2018, 09:53 AM
#43
Thats really helpful Aaron, thanks mate, so are there no problems when the seats are moved back and forth?....think i might run the cable down and under the seat and bring it into the centre console from the side rather than the end. Im assuming you cut and rejoined the cable to get it through the pole?
26-01-2018, 09:53 AM #43
widnes_is200
26-01-2018, 10:01 AM
#44
shaz i removed the bull rings at the bottom of the seat , this gives u enough room (with the seat out too get ure hand right up the back and then a coat hangar too get the last couple of inches, i went from under the centre console so there was no snagging when moving the seat, put the wires u need in first from the head unit, hope this helps
widnes_is200
26-01-2018, 10:01 AM #44
widnes_is200
26-01-2018, 10:02 AM
#45
no dont cut the multi plug! just go too the side, u might lose quality, imho
widnes_is200
26-01-2018, 10:02 AM #45
aaronabbott
26-01-2018, 10:03 AM
#46
SHAHZ Thats really helpful Aaron, thanks mate, so are there no problems when the seats are moved back and forth?....think i might run the cable down and under the seat and bring it into the centre console from the side rather than the end. Im assuming you cut and rejoined the cable to get it through the pole?
absolutely no cutting of cable involved:thumbup1:
aaronabbott
26-01-2018, 10:03 AM #46
26-01-2018, 10:25 AM
#47
widnes_is200 shaz i removed the bull rings at the bottom of the seat , this gives u enough room (with the seat out too get ure hand right up the back and then a coat hangar too get the last couple of inches, i went from under the centre console so there was no snagging when moving the seat, put the wires u need in first from the head unit, hope this helps
So did you feed the wire under the carpet from the centre console to and back out under the seat?
widnes_is200 no dont cut the multi plug! just go too the side, u might lose quality, imho
Nah wasnt going to cut:wink:
26-01-2018, 10:25 AM #47
widnes_is200
26-01-2018, 04:37 PM
#48
yes mate exactly that, under the carpet from the console too the middle of seat
widnes_is200
26-01-2018, 04:37 PM #48
26-01-2018, 08:08 PM
#49
Cool, thanks, gonna try and avoid taking the seats out if i can!
26-01-2018, 08:08 PM #49
27-01-2018, 03:21 AM
#50
DJ Wozza It's four bolts and two plugs mate !!
I know mate, but as I've said before, I'm a lazy b**gg*rBig Grin:laugh::laugh:.....saying that, it would probably be a lot easier if I did!
27-01-2018, 03:21 AM #50
Views 976
23-01-2022, 06:31 PM
Views 2,213
28-04-2019, 04:31 PM
Last Post by jasons
Views 3,595
17-11-2018, 09:24 AM
Last Post by Chri5
Views 2,540
15-03-2018, 10:34 AM
Last Post by Asi
Replies 31
Views 4,231
07-01-2018, 08:49 PM
Last Post by momo88
