JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lack of power
Lack of power
Lack of power
Pages (5): Previous 1 2 3 4 5
Raj
19-04-2017, 04:55 AM
#41
hopefully its nothing major mate
Raj
19-04-2017, 04:55 AM #41
20-04-2017, 12:59 AM
#42
Had it in at Lexus this morning and as I expected they can't find anything wrong. They agreed the idle is a bit low, but not low enough to cause concern.
Only thing they did say is that as I have a "non-restrictive" air filter, it will allow more gunk in (is that true?) so they said if I wanted it I could have the throttle body cleaned for about £100 but they did then say that it's unlikely to help as the sensors are quite sensitive so if there had been a problem it should have thrown up a fault code.
Basically told me to keep an eye on it and call them again if it gets worse. To be fair the car has been behaving itself the last few days so hopefully it was just a temporary glitch Smile
20-04-2017, 12:59 AM #42
20-04-2017, 01:40 AM
#43
Clean your air filter mate, you can get the kit from ebay or opie, will make a big difference....mine has been running well apart from on sunday the idle ramdamly jerked sharply (dipped) a few times while i was at the lights.....been ok otherwise and it didnt do it again.....might still be a bit of oil in the intake from when i over oiled the filter :blushing:
20-04-2017, 01:40 AM #43
20-04-2017, 02:02 AM
#44
SHAHZ Clean your air filter mate, you can get the kit from ebay or opie, will make a big difference....mine has been running well apart from on sunday the idle ramdamly jerked sharply (dipped) a few times while i was at the lights.....been ok otherwise and it didnt do it again.....might still be a bit of oil in the intake from when i over oiled the filter :blushing:
Yeah I'm planning to, it's been added to my ever extending list of things to do which includes "clean the car" :laugh:
20-04-2017, 02:02 AM #44
20-04-2017, 03:08 AM
#45
To be honest i cant remember if my Auto is200 had a sensor fitted to it the sensor is a plug in unit that would go to the Air filter box or induction kits.
If you look at this thread it shown on the induction chrome pipe sitting on the top.
These can get quite dirty so even if it not showing up on the cars ecu it might need a quick clean.
again as said before try borrowing another coil pack and try it in each of the coil packs position to make sure this is not breaking down.
Again this should show up on the engine ecu but it worth a try as well.
http://www.outlawjapclub.co.uk/forum/sho...php?t=1631
Sorry if your already tried these method's
20-04-2017, 03:08 AM #45
Views 295
06-01-2020, 07:01 PM
Replies 25
Views 1,135
14-03-2019, 01:04 PM
Last Post by is300_dino
Replies 23
Views 1,336
29-01-2019, 03:11 PM
Last Post by jomo
Views 376
07-09-2018, 11:53 AM
Views 618
18-01-2018, 04:06 AM
Last Post by LEX11S
Views 984
25-10-2017, 08:18 AM
Last Post by reganlives
Replies 26
Views 1,158
04-10-2017, 12:10 PM
Views 360
28-02-2017, 09:59 AM
Last Post by ibby
Views 410
26-01-2017, 10:08 AM
Replies 24
Views 1,041
07-06-2016, 07:06 AM
Last Post by russelllinn
