Pages (76): Previous 162 63 64 65 6676 Next
02-06-2019, 04:12 PM
a lot off topic , sent you a pm mate.
going off line now , by by LOL
02-06-2019, 04:12 PM #631
Spawn
02-06-2019, 05:22 PM
£212? Christ. I think I used Camskill for mine.. muuuuch cheaper!
Spawn
02-06-2019, 05:22 PM #632
14-06-2019, 04:47 PM
Fixed the amp for the subs today - it had a blown MOSFET so it shorted the power supply and went straight into 'protect'. Whipped it to bits, found the blown one and replaced it for about £8. Sods law that something would give up after I'd taken the deposit!
Also wired up the mirrors to autoclose/open with the alarm. It's a feature Dan's IS200 had and I quite liked it. Only took 2 diodes and 1 bit of wire!
14-06-2019, 04:47 PM #633
14-06-2019, 06:13 PM
hows long left mate?
14-06-2019, 06:13 PM #634
Spawn
14-06-2019, 06:19 PM
Hey mate.
We may need to reschedule the collection date if that's ok? I can't get the time off work until the Wed 3rd, but I have a wedding rehearsal that evening, then a birthday on the 4th, Friday 5th would be one option for me. Got a wedding on the 6th (saturday) then free again on the 7th (sunday).
But will have to be even later if not convenient for you Smile
Rob
Spawn
14-06-2019, 06:19 PM #635
Hey mate.
Rob
14-06-2019, 06:32 PM
I was gonna call you about that anyway, because we originally said the 1st, but I won't get back from Germany until like 11pm!
14-06-2019, 06:32 PM #636
Spawn
14-06-2019, 06:36 PM
Thats ok then Smile. Do you want to give me a call before you leave or even after your back? we'll sort something out.
Spawn
14-06-2019, 06:36 PM #637
14-06-2019, 07:35 PM
I just read the whole of this :')
14-06-2019, 07:35 PM #638
Fozzy
15-06-2019, 05:30 AM
toxo Fixed the amp for the subs today - it had a blown MOSFET so it shorted the power supply and went straight into 'protect'. Whipped it to bits, found the blown one and replaced it for about £8. Sods law that something would give up after I'd taken the deposit!
Can you tell me which wires, as i want to wire mine to do the same.....once i wire in the retracting mirrors!
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
15-06-2019, 05:30 AM #639
15-06-2019, 05:46 AM
Hurricane Can you tell me which wires, as i want to wire mine to do the same.....once i wire in the retracting mirrors!
On the rear window slider there are 2 wiring connectors, 1 is 3 pin and 1 is 4 pin. The 4 pin one has a blue wire with a white stripe and a blue wire with a black stripe - it's these 2 in my car. Basically, one is +12v for lock and the other is +12v for unlock. You connect them to the pink wire for the mirror retract switch with a diode for each wire to make sure that current can only flow from the blue wires to the pink wire. Then every time you lock or unlock the car the pink wire sees +12v. Wiring looms tend to be different colours import/UK though, so as you have the female connector in your hand (the one that's NOT attached to the window slider) looking into the pin end not the wire end it's top right and bottom right.
Edited 27-07-2011, 09:33 AM by toxo.
15-06-2019, 05:46 AM #640
Views 3,432
Views 3,958
Views 14,018
Views 6,883
Views 34,706
Replies 79
Views 11,129
02-09-2024, 04:19 PM
Views 5,117
Views 10,505
Views 1,616
Views 1,954
