Pages (76): Previous 163 64 65 66 6776 Next
Fozzy
15-06-2018, 12:02 AM
Excellent, cheers mate. You make it sound so easy, im sure it will be obvious once i pull it all apart. Im going to bet on different wire colours as mine is a UK n/a, but should be in the same pin location
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
15-06-2018, 12:02 AM #641
15-06-2018, 12:05 AM
Hurricane Excellent, cheers mate. You make it sound so easy, im sure it will be obvious once i pull it all apart. Im going to bet on different wire colours as mine is a UK n/a, but should be in the same pin location
On mine they're the same colours on the doorlock mechanism itself so you might be in luck there. They are the same colour on retract and non retract import looms (I have both types here) which bodes well.
The only problem is getting access in there to solder and heatshrink, you have to take quite a bit of sheath back.
It's not perfect in mine yet, the alarm seems to send an unlock signal if you've put the keys in the ignition but not started the car, then you take the keys out. So then the mirrors get out of sync with the door lock. I think I know how to fix that though Smile
Edited 27-07-2011, 09:41 AM by toxo.
15-06-2018, 12:05 AM #642
Dark Samurai I just read the whole of this :')
One way to kill time I guess Smile What did you think?
15-06-2018, 12:05 AM #643
15-06-2018, 03:15 AM
Honestly I think it's a nice car.
I don't like the wheels, sorry mate.
But sorry for asking a stupid question, but I saw you replaced a "rotor arm" and "dizzy cap", what on earth are these magical contraptions?
15-06-2018, 03:15 AM #644
Fozzy
15-06-2018, 03:39 AM
Ignition systems, before the days of coil packs. The rotor arm is attached to a camshaft and spins within the distributor cap, sending power down each of the 4 HT leads when it is in the correct position
Fozzy
15-06-2018, 03:39 AM #645
15-06-2018, 03:47 AM
Thanks Pete Smile
15-06-2018, 03:47 AM #646
Thanks Pete Smile
15-06-2018, 04:52 AM
i've gone back in time from the Lex where it's coil on plug to the days of HT leads on the Supe Smile
15-06-2018, 04:52 AM #647
15-06-2018, 04:59 AM
You will be COP again with the -GTE though Smile
As Pete said, oldschool ignition system. As it happens the 3S-GTE runs what Toyota called a 'hybrid' ignition system where it still uses a distributor and a spinning rotor to distribute the spark amongst the HT leads, but the contact point on the rotor is quite long, so the ECU can vary when it sends the spark to alter the ignition timing. You set the base timing by rotating the distributor on the end of the cam shaft (the mounting holes are slotted) but then the ECU fine tunes it.
Edited 27-07-2011, 02:34 PM by toxo.
15-06-2018, 04:59 AM #648
15-06-2018, 05:00 AM
[COLOR="DarkOrchid"]proper days, proper mechanics that even witches can cope with ... although i have to say i don't like how much HT leads cost for supras these days
Oh how I miss those days of having to spray damp start into the cap while trying not to freeze fingers to the bonnet
Now who do i hit for having 'I'm so dizzy, my head is spinning, like a whirlpool, it never ends' stuck in my head [/COLOR]
Edited 27-07-2011, 02:35 PM by purplewitch.
15-06-2018, 05:00 AM #649
15-06-2018, 05:03 AM
purplewitch proper days, proper mechanics that even witches can cope with ... although i have to say i don't like how much HT leads cost for supras these days
Think they are cheaper than the leads for the MR2 these days, even though there are 2 more and they are longer!!
In fact I just checked, we just ordered a load for Dan's car. This is how it breaks down:
Supra HT leads (set of 6) £95.91
MR2 HT leads (set of 4) £92.68
Supra Distributor Cap (6 output) £17.59
MR2 Distributor Cap (4 output) £57.82
Supra Rotor Arm £8.02
MR2 Rotor Arm £13.64
purplewitch Now who do i hit for having 'I'm so dizzy, my head is spinning, like a whirlpool, it never ends' stuck in my head
Dan
Edited 27-07-2011, 02:46 PM by toxo.
15-06-2018, 05:03 AM #650
Dan
 4 Guest(s)
 4 Guest(s)
Views 876
31-10-2023, 10:05 PM
Views 1,460
08-10-2023, 03:59 AM
Views 5,927
06-10-2023, 02:58 AM
Views 3,088
04-10-2023, 03:52 PM
Views 21,935
10-09-2023, 07:50 PM
Replies 79
Views 4,225
03-09-2023, 10:30 AM
Views 1,922
17-05-2023, 11:25 AM
Views 6,360
05-05-2023, 01:09 PM
Views 857
18-03-2023, 01:09 PM
