Pages (17): Previous 15 6 7 8 917 Next
phaebo
05-06-2021, 01:46 PM
#61
Hey daniel, I got a spare supercharger wich i am rebuilding at the moment. I also bought a rebuild kit from jonbondperformance.com. How did you fit the front rotor bearings? Did you use the retainer rings or did you do some loctite on the bearings?
phaebo
05-06-2021, 01:46 PM #61
Daniel N
05-06-2021, 01:56 PM
#62
Hi Phaebo
I used a hydraulic press. It is a must when doing this rebuild.
Yes I used the retainer rings by TIG welding them.
I have a bit of photos of my rebuild on a Danish car site. Heres a link http://www.bilgalleri.dk/fotoalbum/tunin...renovering
You may have to register :-(
Daniel N
05-06-2021, 01:56 PM #62
Hi Phaebo
rob
05-06-2021, 02:12 PM
#63
Oh! Didnt know you pressed the shafts out ! Good site find ! Any problems lining up the rotors again ?
rob
05-06-2021, 02:12 PM #63
Daniel N
05-06-2021, 02:26 PM
#64
Yes you press the shafts out of the rotors. Yep thats the main car mods site here in Denmark :-).
No not really. Just make sure to mark the rotors and gears while disassembling and just take your time with it. But you will need a press.
Daniel N
05-06-2021, 02:26 PM #64
phaebo
05-06-2021, 02:30 PM
#65
Hey thanks for the pics and answers. Very usefull pics. And yes i have a press. I allready got my parts but now need to press the bearings in. And tig weld the retainer rings. But i got the time because this is a spare charger. Thx for the info
phaebo
05-06-2021, 02:30 PM #65
Daniel N
05-06-2021, 03:00 PM
#66
No problem. I'm glad I could help a bit
Daniel N
05-06-2021, 03:00 PM #66
phaebo
12-06-2021, 07:01 AM
#67
Daniel did the yellow injectors have a black cap on the underside or just metal? I am asking because my 1zzfe injectors did have a black cap
phaebo
12-06-2021, 07:01 AM #67
12-06-2021, 08:59 AM
#68
phaebo Daniel did the yellow injectors have a black cap on the underside or just metal? I am asking because my 1zzfe injectors did have a black cap
They must have a black cap!
12-06-2021, 08:59 AM #68
phaebo
12-06-2021, 09:01 AM
#69
Dimis did your yellow injectors that you used to have have black caps on?
phaebo
12-06-2021, 09:01 AM #69
12-06-2021, 09:03 AM
#70
phaebo Dimis did your yellow injectors that you used to have have black caps on?
Yes they had and I replaced them with a new set.
12-06-2021, 09:03 AM #70
Views 839
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 327
01-07-2023, 06:27 PM
Last Post by lexusdaydreaming
Views 554
14-09-2022, 01:32 PM
Last Post by P.Lindblom
Views 776
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 452
26-07-2022, 05:09 PM
Last Post by reganlives
Views 488
30-03-2022, 09:15 PM
Views 429
13-03-2022, 11:27 PM
Last Post by deccie22
Views 693
17-09-2021, 09:42 PM
Last Post by gsitlv
