Project T-Sport...
Project T-Sport...
cheers bud, theres alot of trim to do so may just buy a cheapo small pack and give it a bash, do you have to use a hair dryer though? would warm water not work also the same as when you apply stickers to car bodywork?
it's not a waterslide decal, it is actually sticky back plastic (basically) I've found a Hairdryer works best, as it makes the wrap supple, and if you get it wrong you can just peel it back of and re-apply.
What I did was I bought 2 A4 sheets for about £3 each. Then once I was happy with how it looked, I bought a roll.
Start small first, just to test it..
But it does work better with using heat to apply it.. Check Youtube for some videos of what can be achieved with it..
http://www.youtube.com/watch?v=vxpq_32XP...895665ED8B
http://www.youtube.com/watch?v=I3SJRPha9...re=related
http://www.youtube.com/watch?v=Odw8ZQD0gHk
http://www.youtube.com/watch?v=MACyXJ7jM...re=related
Well installed the LED sidelights (what a PITA that was) had to get my brother-in-law with girly thin hands to do drivers side!!
I'm after a bit of guidance for installing the HiD's without bumper removal..... Do I need to cut into the protective cover that covers the rear of the lights?
Hi guys, managed to finally get the HiD's fitted (yes Anees at last!!!)
What I need to know is it easy/possible to remove the spolier from my car? I have a plan :biggrin:
