JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Rubbish radio reception!
jomo
13-06-2019, 12:54 PM
Ever since i fitted and after market headunit in the is200 i'v had rubbish radio reception?
It's a brand new unit so not faulty as it had rubbish reception with thge previous Kenwood mp3 unit?
Does the std powered ariel not like after market units?
jomo
13-06-2019, 12:54 PM #1
13-06-2019, 01:22 PM
Have you given the existing antenna a power source as it draws it from the radio noally if you haven't then it won't work right......
13-06-2019, 01:22 PM #2
I have the same problem.
13-06-2019, 01:22 PM #3
jomo
13-06-2019, 01:24 PM
Rabster Have you given the existing antenna a power source as it draws it from the radio noally if you haven't then it won't work right......
Ah er no!
So wheres the power wire that needs a feed?
And is it a 12v feed it needs?
jomo
13-06-2019, 01:24 PM #4
Ah er no!
13-06-2019, 02:12 PM
It's a black cable running along the antenna cable it needs a 12v ignition feed or the antena out on aftermarket radios give 12v
Cable located right hand side of the radio opening
13-06-2019, 02:12 PM #5
jomo
14-06-2019, 07:19 AM
Hi Rabs, had a quick look just now through the single din opening and couldnt see or feel any extra black cable that runs along the antena cable?
Is it way in the depths behind the faceplate?
Cheers BTW.
jomo
14-06-2019, 07:19 AM #6
Cheers BTW.
14-06-2019, 09:16 AM
It is easier to see with the whole lot removed. (double din out).
14-06-2019, 09:16 AM #7
jomo
14-06-2019, 02:31 PM
FirebirdPhil It is easier to see with the whole lot removed. (double din out).
Bah! ok ill have to wait till weekend.
Cheers all, let you know how i get on.
jomo
14-06-2019, 02:31 PM #8
15-06-2019, 08:57 AM
It has a white connector on it well mine did all I did was run the feed to the radio can't remember which but its very simple I even get AM which I didn't get before
15-06-2019, 08:57 AM #9
jomo
15-06-2019, 09:09 AM
Thanks Pat, where abouts did you find the connector, i,v got a feeling that i saw it when iv had the stereo out a few times and its behind the heated seat area at the back!
jomo
15-06-2019, 09:09 AM #10
Views 686
25-04-2019, 11:55 AM
Last Post by el_gencer
Views 830
23-03-2019, 10:37 AM
Last Post by andymunro
Views 1,006
11-02-2019, 01:41 PM
Last Post by northernmonkey
Views 636
17-04-2018, 11:18 AM
Last Post by Chri5
Views 3,185
12-07-2017, 11:40 PM
