JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza A/c Removal and no Refit
164
30-06-2019, 03:03 AM
Hi guys just want to know, im sure my a/c not working anyway, and never use it, if i remove it, the pump pipe, condencer/radiator, will i get any faults, or is anything that is needed connected to this system? also the a/c pully close to my S/c piping and has touched at some point made a bit of a mess of the edge of the a/c pully so just want to take it off, seen it can be done but its been on older less electrical controlled car.
so don't want to do it if im guna be getting DTC's
lookatmybiceps
30-06-2019, 03:03 AM #1
30-06-2019, 03:28 AM
im sure you can just remove it all with out any fault popping up from the ecu so you should be fine to disconect it all, stavs removed his to relocate his alternator
30-06-2019, 03:28 AM #2
30-06-2019, 03:59 AM
But I've got a standalone ecu remember.
You may get a code cause the ecu reads the air con system pressure and temp. But theyre more for the rad fan for that side.
Remind me later and I'll have a look.
30-06-2019, 03:59 AM #3
mattlaw
30-06-2019, 07:59 AM
Just remove the belt and don't use the aircon
mattlaw
30-06-2019, 07:59 AM #4
164
30-06-2019, 08:38 AM
yeah but if not using id want to take it out.
lookatmybiceps
30-06-2019, 08:38 AM #5
30-06-2019, 12:01 PM
A/C cannot throw a engine code.
It is a heck of a lot of work to remove the whole system - dash out etc. You will save a lot of weight doing this probably not enough to make any real world difference apart from destroying any resale valve of the car.
30-06-2019, 12:01 PM #6
mikey bean
30-06-2019, 12:06 PM
bin it off. i removed the lot from my car. pump, rad, ac matrix and all piping. i saved a lot of weight. great if your after performanceSmile
mikey bean
30-06-2019, 12:06 PM #7
30-06-2019, 01:20 PM
mikey bean great if your after performanceSmile
Yeah, great in that performance... is200.... performance machine....
30-06-2019, 01:20 PM #8
164
01-07-2019, 12:04 AM
Ah ok good, just wanted to check no codes guna come from taking it out. yeah know it wont do that much, but want to clean engine bay out if its not getting used it getting riped out! also going to relocate the battery. But the state my car is in there is no point thinking about REsale. Im keeping it forever! Wink
lookatmybiceps
01-07-2019, 12:04 AM #9
Views 185
23-10-2019, 03:14 PM
Last Post by Jk 200sx
Replies 25
Views 1,183
08-08-2019, 01:11 PM
Last Post by Chris0121
Replies 22
Views 850
02-02-2019, 09:37 AM
Last Post by Jimbob-T-Lex
Views 453
15-12-2018, 09:55 AM
Last Post by Barry
Views 422
03-10-2018, 08:13 AM
Views 825
22-03-2018, 07:15 AM
Views 340
04-05-2017, 06:18 AM
Last Post by reganlives
Views 328
25-01-2017, 10:32 AM
Views 349
31-12-2016, 05:48 AM
Last Post by Andy-R.
