JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission gearbox whine
gearbox whine
gearbox whine
JayJay1374
21-08-2019, 12:16 PM
hello, i ment to post the 15,000 miles ago put kept forgetting lol.
after fitting a new clutch i still had a whining noise, much like a release bearing noise (but that was replaced) when the clutch is up you can hear the noice, but when its down its silent. Since it had a new clutch all i can think of is the gearbox input shaft bearing?
the box has been replaced at some point, it also has a crunch in 3rd when cold, sounds like a new gearbox could be the cure?
http://www.facebook.com/Sxe10CrewUk
Stickers available!!!, PM me.
JayJay1374
21-08-2019, 12:16 PM #1
S
23-08-2019, 11:02 AM
the crunch is normal mate, or at least mine does it too!
S
23-08-2019, 11:02 AM #2
Lance79
01-09-2019, 09:15 AM
Mine had that chirping sound at idle with the clutch pedal up, found it was the release fork rubbing against the shaft. A good squirt of white lithium grease in the hole by the slave cylinder solved it!
Lance79
01-09-2019, 09:15 AM #3
01-09-2019, 01:08 PM
Lance79 A good squirt...
What are you thinking Lance, 40 weight... 50 weight?
01-09-2019, 01:08 PM #4
JayJay1374
01-09-2019, 01:09 PM
40 weight sounds nice....
JayJay1374
01-09-2019, 01:09 PM #5
Lance79
01-09-2019, 03:05 PM
el_bandido What are you thinking Lance, 40 weight... 50 weight?
What do you mean?
Lance79
01-09-2019, 03:05 PM #6
What do you mean?
JayJay1374
01-09-2019, 03:06 PM
It's a quote from the first fast and furious :lol:
JayJay1374
01-09-2019, 03:06 PM #7
Lance79
01-09-2019, 03:19 PM
Aw right! I never did get to see it, must get it out sometime!
See about this noise? Does it go away when you put a bit of pressure on the clutch pedal?
As for the crunch I don't know, could be synchro wear. I put this oil in mine and it eliminated the notchy shift between 1st and 2nd. It's worth a try.
http://www.opieoils.co.uk/p-1020-red-lin...0-gl4.aspx
Edited 13-10-2012, 12:53 AM by Lance79.
Lance79
01-09-2019, 03:19 PM #8
JayJay1374
01-09-2019, 03:22 PM
It's a whine when the clutch is up. You can hear it when driving. I think I'm just gonna swap the box over from my other lex!
JayJay1374
01-09-2019, 03:22 PM #9
Views 290
28-01-2021, 10:36 AM
Last Post by 1374lee
Views 366
29-08-2020, 11:41 AM
Last Post by Connor376
Views 1,571
19-11-2018, 06:19 AM
Views 529
24-06-2018, 03:24 AM
Last Post by Biglee 22
Views 536
18-01-2018, 10:44 AM
Views 505
02-06-2017, 10:54 PM
Last Post by TM
Views 564
23-12-2016, 09:40 AM
Views 546
02-11-2016, 10:07 AM
Last Post by aaronabbott
