JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Gearbox compatibility
23-12-2016, 02:22 AM
Is the manual gearbox of the altezza 3SGE the same with the Lexus IS200 1GFE?:glare:
23-12-2016, 02:22 AM #1
23-12-2016, 02:34 AM
do you mean RS200 altezza or AS200?
23-12-2016, 02:34 AM #2
23-12-2016, 02:56 AM
Dan_Turism0 do you mean RS200 altezza or AS200?
The AS200 has a 1gfe Engine mate Big Grin
But think the bell housings are different on the 3s-ge engine/gearbox??
Edited 03-02-2010, 12:35 PM by Bandit.
23-12-2016, 02:56 AM #3
23-12-2016, 03:21 AM
There are also slight casting differences to the actual box, as we found out when putting the RS200 box onto my car.
23-12-2016, 03:21 AM #4
23-12-2016, 03:50 AM
No I don't think it's the same box.
23-12-2016, 03:50 AM #5
23-12-2016, 03:56 AM
They are pretty much the same apart from the bell housing, all the gear ratios are identical. However a manual RS200 'box is rare.
23-12-2016, 03:56 AM #6
23-12-2016, 04:05 AM
I stand corrected, looking at the parts they are the same boxes (J160) and the same gears, as Phil says, with different bell-housings to mate to the different engines. The bit that plugs into the gearbox to drive the speedo is different too though.
23-12-2016, 04:05 AM #7
23-12-2016, 04:53 AM
sigh I did not read properly Sad
23-12-2016, 04:53 AM #8
23-12-2016, 09:40 AM
Ok thanks mates. I just wanted to know if the short shifts for the RS200 or other Altezza versions much on the IS200. All of you have covered my question.
23-12-2016, 09:40 AM #9
Views 291
28-01-2021, 10:36 AM
Last Post by 1374lee
Views 367
29-08-2020, 11:41 AM
Last Post by Connor376
Views 590
01-09-2019, 03:22 PM
Last Post by JayJay1374
Views 1,571
19-11-2018, 06:19 AM
Views 529
24-06-2018, 03:24 AM
Last Post by Biglee 22
Views 536
18-01-2018, 10:44 AM
Views 505
02-06-2017, 10:54 PM
Last Post by TM
Views 546
02-11-2016, 10:07 AM
Last Post by aaronabbott
