JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission gearbox swap
gearbox swap
gearbox swap
Biglee 22
24-06-2018, 01:39 AM
morning guys, just wondering how easy it is to swap my auto box for a manual box in my is200,i work at a car breakers and we have just had one come in and i can have whatever bits i need to do the swap.
I am assuming it will be something along the lines of;
Flywheel,
Clutch,
Gearbox,
Propshaft,
Pedal box/Clutch Master.
Some wiring/ECU ?,
Gearstick/Interior trim.
What about the diff ratios ? Will that be different too !? And I notice the speedometer is different but will the manual one just swap ?
I am hoping one of you may have already completed this swap and could just give a little guidance before we jump in and find all sorts of problems !!
Thanks in advance.
Lee
Biglee 22
24-06-2018, 01:39 AM #1
Flywheel,
Clutch,
Gearbox,
Propshaft,
Some wiring/ECU ?,
Thanks in advance.
Lee
24-06-2018, 01:52 AM
Erm its quite a bit of work.
youve listed most of the right parts, but then the ecu is linked with the key i think so youll need to sort that out. the diff shouldnt be a problem no.
24-06-2018, 01:52 AM #2
24-06-2018, 02:12 AM
As Stav says, a lot of work! Never heard of it ever being done, although someone might have.
Personally I'd sell the auto and buy a manual. Unless the car holds sentimental value? That way you could get a Sport too!
24-06-2018, 02:12 AM #3
24-06-2018, 02:40 AM
Smile See, I'd consider an IS300 if I could get it as a manual - I'm just not a fan of automatics Big Grin
24-06-2018, 02:40 AM #4
24-06-2018, 02:56 AM
Almost finished has had the auto to manual conversion one....
24-06-2018, 02:56 AM #5
Biglee 22
24-06-2018, 03:00 AM
i dont mind hard work lol,the key is not a problem as ive just installed a clifford alarm and remote start i took the chip out and put in the dash so all ive got too do is change that over. I was thinking off selling it and getting a manual but because it was a cat d car i dont know if i would get much for it but i will check and ive put in the clifford and started the hifi install in it, iam now in the mix of stripping the car as the car that came in the yard had black interior where mine is cream so i will so iam swapping that over, iam stripping the car at work now so if and when i do i will post some pics up,
cheers guys
lee
Biglee 22
24-06-2018, 03:00 AM #6
cheers guys
lee
Biglee 22
24-06-2018, 03:24 AM
my friend just stripped his whole car to a bare shell to change the loom and autobox for manual ones, so he has a good idea of the work involved but still is not afraid lol.
Biglee 22
24-06-2018, 03:24 AM #7
Views 237
28-01-2021, 10:36 AM
Last Post by 1374lee
Views 279
29-08-2020, 11:41 AM
Last Post by Connor376
Views 473
01-09-2019, 03:22 PM
Last Post by JayJay1374
Views 310
19-07-2019, 02:44 AM
Views 345
04-07-2019, 07:01 AM
Last Post by Mikey
Views 1,282
19-11-2018, 06:19 AM
Views 502
18-01-2018, 10:44 AM
Views 461
02-06-2017, 10:54 PM
Last Post by TM
Views 455
23-12-2016, 09:40 AM
Views 434
02-11-2016, 10:07 AM
Last Post by aaronabbott
