JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Gearbox Oil Change
Gearbox Oil Change
Gearbox Oil Change
Pages (3): 1 2 3 Next
05-11-2018, 04:54 AM
Hi all,
How easy is it to change the gearbox oil on the is200, and what would people suggest is a good choice of oil to use.
May even make a walkthru and post in the help section.
Also how much oil do I need for the gearbox
Thanks
Pat
05-11-2018, 04:54 AM #1
Hi all,
Thanks
Pat
05-11-2018, 05:13 AM
Manual or Auto?
Manual 'box shouldn't ever need changing.
05-11-2018, 05:13 AM #2
Manual or Auto?
05-11-2018, 05:17 AM
Sorry Phil, its a Manual
Why should it never need changing is this just on the IS200 as in other cars I have had I've always done it as part of a major service, I just never did it when I did the service on the lexus
05-11-2018, 05:17 AM #3
05-11-2018, 05:32 AM
Most manual boxes under normal operation conditions don't need oil changes. You won't find a service manual saying to service a manual box by changing the oil, almost regardless of manufacturer.
Take a look through your service schedule.
05-11-2018, 05:32 AM #4
05-11-2018, 05:37 AM
As I have always bought second hand cars its something I've always done along with everything else just to be 100% happy that the car is in good working order.
Would a change do any harm to the gearbox as at some point it will be coming off for the exedy clutch to be fitted
05-11-2018, 05:37 AM #5
05-11-2018, 05:45 AM
It won't harm it, do it when the 'box is off.
Its Autos you have to be careful off, if there is damage in the box maybe due to a lack of service/fluid changes wrong fluid, wrong method of changing etc, a fluid change can in fact cause more damage and ultimately failure.
05-11-2018, 05:45 AM #6
05-11-2018, 05:48 AM
Glad I don't have an Auto then, thanks for that advice Phil
May have to do it when I change the clutch then
05-11-2018, 05:48 AM #7
05-11-2018, 05:53 AM
Autos are OK if you and previous owners followed the maintenance instructions.
05-11-2018, 05:53 AM #8
05-11-2018, 07:19 AM
Manual says every 4 years/40K
05-11-2018, 07:19 AM #9
05-11-2018, 07:52 AM
Well I've seen the stuff on opieoils for the gearbox so may invest in some
05-11-2018, 07:52 AM #10
Views 237
28-01-2021, 10:36 AM
Last Post by 1374lee
Views 279
29-08-2020, 11:41 AM
Last Post by Connor376
Views 473
01-09-2019, 03:22 PM
Last Post by JayJay1374
Views 345
02-09-2018, 11:45 AM
Views 442
24-06-2018, 03:24 AM
Last Post by Biglee 22
Views 502
18-01-2018, 10:44 AM
Views 461
02-06-2017, 10:54 PM
Last Post by TM
Views 455
23-12-2016, 09:40 AM
Views 434
02-11-2016, 10:07 AM
Last Post by aaronabbott
Views 711
16-07-2016, 11:16 PM
Last Post by kam05
