JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Mystery battery death (round two)
Pages (3): 1 2 3 Next
04-11-2019, 05:29 AM
Ok folks, usual suspects for causing a battery to drain in an IS200?
It's definitely not the battery as I only replaced this one in April. My stereo double din unit no longer works, so it may have something to do with that (though it doesn't power on), but I doubt it.
This did happen to be a while ago, but went away for some reason. Can't see any evidence of water damage. Any time the car is sat for more than a day or so, the battery goes dead.
edit: quick google search suggests the amplifier may be at fault. The wiring behind my double din is a mess though, whoever installed it was a bit of a retard.
edit 2: if I remove the audio fuse and leave it for a few days, is this going to work as a diagnostic way of seeing if it's the audio?
Edited 15-12-2012, 03:13 PM by el_bandido.
04-11-2019, 05:29 AM #1
04-11-2019, 08:18 AM
Problem is the radio fuses control a lot of other stuff. I'd remove the unit, tape off all the wires and try that.
04-11-2019, 08:18 AM #2
Lucas
04-11-2019, 08:46 AM
Sorry for asking, but why you not check it with multimeter?It's only and easy way to check consumption .If its gonna be big you can start to unplug things like stereo etc...
Lucas
04-11-2019, 08:46 AM #3
04-11-2019, 09:05 AM
Lucas Sorry for asking, but why you not check it with multimeter?It's only and easy way to check consumption .If its gonna be big you can start to unplug things like stereo etc...
because I left my multimeter in Northampton.
I've unplugged the stereo 1 fuse or whatever it's called. 20A 3rd one down. I did notice that an annoying ticking from the passenger side interior is now gone, so I'm wondering if a relay is damaged somewhere.
Stav - what else does that fuse connect to?
04-11-2019, 09:05 AM #4
04-11-2019, 09:54 AM
Def sounds like a wiring issue mate.
Not sure about the fuse as I'm not at home. But it's on the bahamutcars website under 'power source matrix'
04-11-2019, 09:54 AM #5
04-11-2019, 10:14 AM
cool, cheers.
The wiring behind this stereo is literally the most retarded thing I've ever seen. It also looks as if someone has clipped bits off and tried to take power from all over the place.
I'm going to put a car pc in soon anyway, so I'll probably just rip everything out and put an after market amp in.
I'll see if the battery drains now the fuse is removed.
04-11-2019, 10:14 AM #6
cool, cheers.
04-11-2019, 10:56 AM
It enough. I'm happy enough to have a look for you if you come my way.
04-11-2019, 10:56 AM #7
06-11-2019, 07:37 AM
success, car still has charge! Definitely stereo circuit.
06-11-2019, 07:37 AM #8
06-11-2019, 08:49 AM
Well bring it up here and well figure it out
06-11-2019, 08:49 AM #9
06-11-2019, 11:51 AM
will do mate, Barclays should pay up just before new years and I've got exams all Jan, I'll give you a shout in Feb if you don't mind?
06-11-2019, 11:51 AM #10
Views 324
30-08-2019, 04:29 AM
Last Post by Phil01
Replies 24
Views 1,668
16-12-2018, 10:47 AM
Last Post by Stoney
Views 753
27-11-2018, 06:46 AM
Last Post by el_gencer
Views 814
10-10-2018, 09:55 AM
Views 576
30-08-2018, 03:13 PM
Last Post by Stoney
Views 521
27-04-2018, 05:49 AM
Last Post by jimxms
Views 681
28-11-2017, 04:28 AM
Last Post by Phil01
Views 621
29-09-2017, 01:50 AM
Views 319
18-03-2017, 07:43 AM
