JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Brake Upgrade
Brake Upgrade
Brake Upgrade
23-03-2020, 03:00 PM
Just wondering if it would be possible to fit the front disc's, pads and calipers from a 300zx twin turbo onto the IS without too much work being involved. Reason I ask is because I have a set at home which if they will fit with a relative amount of ease, I may as well use as a decent upgrade . . . . . . .
If not then I will at some point be putting them up for sale (once they have been removed of course :lolSmile
23-03-2020, 03:00 PM #1
S
23-03-2020, 03:28 PM
cougarrsv Just wondering if it would be possible to fit the front disc's, pads and calipers from a 300zx twin turbo onto the IS without too much work being involved. Reason I ask is because I have a set at home which if they will fit with a relative amount of ease, I may as well use as a decent upgrade . . . . . . .
Are they radial mount calipers?
S
23-03-2020, 03:28 PM #2
23-03-2020, 03:44 PM
Almost_Finished has skyline brakes on his if I remember correctly, might be similar. Give him a shout.
23-03-2020, 03:44 PM #3
No idea tbh, will have a look and find out tomorrow
23-03-2020, 03:44 PM #4
If you take them off I got a guy who can make you some steel brackets similar to the figs ones that some use or failing that I know that almost finished is running 350z brembos on his I'm sure I could sweet talk him into letting me at his car to get the brackets copied.....
23-03-2020, 03:44 PM #5
23-03-2020, 03:45 PM
el_bandido Almost_Finished has skyline brakes on his if I remember correctly, might be similar. Give him a shout.
350z calipers front and rear
23-03-2020, 03:45 PM #6
23-03-2020, 03:46 PM
I believe the skyline r33 and 300zx run the same brakes so if he has thats handy to know. I do know its a very popular mod with the s14
23-03-2020, 03:46 PM #7
23-03-2020, 03:48 PM
Rabster If you take them off I got a guy who can make you some steel brackets similar to the figs ones that some use
That's good to know, will see what I can sort out and let you know.
23-03-2020, 03:48 PM #8
23-03-2020, 03:52 PM
you might need an RCA spacer to stop it hitting the hub knuckle by the way. I did with the LS400 4-pots and 315mm disks.
23-03-2020, 03:52 PM #9
23-03-2020, 03:53 PM
Rabster 350z calipers front and rear
From Dave's thread: Brembo skyline gold four pots front/rear .
23-03-2020, 03:53 PM #10
Views 275
16-06-2022, 03:51 AM
Views 365
12-12-2020, 10:51 AM
Last Post by phaebo
Views 437
16-10-2020, 07:33 AM
Last Post by Mr-cth
Views 739
11-11-2019, 01:41 AM
Views 601
30-07-2019, 08:00 AM
Views 803
13-04-2019, 12:57 PM
Last Post by LEXOB
Views 658
11-01-2019, 11:21 AM
Views 778
01-07-2018, 01:41 AM
Last Post by E55EX_RACER
Views 263
28-12-2017, 05:24 PM
Last Post by LEX11S
Views 700
24-12-2017, 07:45 AM
Last Post by aaronabbott
