JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension brake caliper carriers
Mr-cth
13-10-2020, 11:33 PM
Hi all, havin abit of trouble with the brake caliper carrier on me is200, went to change pads at weekend and one of the sliding pins has siezed solid cudnt even move it with the help of a lump hammer!!.
So anyway looks lik it needs replacing I was just wondering if it will be the same as the gs300 and any other lexus models just to make it abit easier to find??
Any help much appreciated!
Mr-cth
13-10-2020, 11:33 PM #1
14-10-2020, 01:47 AM
I've got a pair of used front caliper carriers from when I fitted my FIGS upgrade carriers...
This pic isn't mine, but just to double check, it's a pair of these you're after?
[Image: %24T2eC16ZHJHQE9nzEy8tsBRPI8nRJOg~~60_35.JPG]
14-10-2020, 01:47 AM #2
Mr-cth
14-10-2020, 02:06 AM
That is exactly what I'm after just the passenger side tho, where are u based? Do you know would they be the same as the gs carriers?
Mr-cth
14-10-2020, 02:06 AM #3
14-10-2020, 02:33 AM
To be honest I'm not sure, but it's possible they might be...
I'm near Oxford, could probably post 1 or both fairly cheap if required.
Sent from my LT26i using Tapatalk
14-10-2020, 02:33 AM #4
14-10-2020, 03:50 AM
Had a simialar issue solution was heat, AJ and a hammer finally got the one out that was stuck and then greased it really well working it in the gap
14-10-2020, 03:50 AM #5
Mr-cth
14-10-2020, 07:56 AM
aye I tried beating it with a hammer and also managed to snap my spanner off trying to twist it so think get another sorted would be the plan, that would be great sprinter do you know how much it would cost to send it to London?
Mr-cth
14-10-2020, 07:56 AM #6
14-10-2020, 08:15 AM
I'll bring one into work tomorrow and weigh it so I can give you a price.
14-10-2020, 08:15 AM #7
16-10-2020, 05:35 AM
Totally forgot to bring one in today, but I just had a quick look on Royal Mail and I'm sure it will fit into their 'Small Parcel' category, so I can post 1 for £6.85. Two together would take it over the 2kg limit, so I'd send it another way if you wanted a pair.
16-10-2020, 05:35 AM #8
Mr-cth
16-10-2020, 07:33 AM
Cheers mate you have a pm
Mr-cth
16-10-2020, 07:33 AM #9
Views 275
16-06-2022, 03:51 AM
Views 364
12-12-2020, 10:51 AM
Last Post by phaebo
Views 534
23-03-2020, 04:20 PM
Views 739
11-11-2019, 01:41 AM
Views 601
30-07-2019, 08:00 AM
Views 803
13-04-2019, 12:57 PM
Last Post by LEXOB
Views 658
11-01-2019, 11:21 AM
Views 778
01-07-2018, 01:41 AM
Last Post by E55EX_RACER
Views 263
28-12-2017, 05:24 PM
Last Post by LEX11S
Views 699
24-12-2017, 07:45 AM
Last Post by aaronabbott
