JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Brake cylinder
Brake cylinder
Brake cylinder
04-01-2019, 12:01 PM
Right im going to start installing my line lock before i put the engine back in as ive more room to work in the engine bay lol
but i need to install it between the abs actuator and the master cylinder. My question is, which line from the master cylinder is for the front brakes?
theres 2 that then go to the actuator then split into 4 to go to each wheel.
I dont want to guess then find ive locked the rear wheels! doh.
ive tried Bahamut cars but no answers
04-01-2019, 12:01 PM #1
10-01-2019, 02:10 PM
Anyone able to help?
10-01-2019, 02:10 PM #2
Talisker
10-01-2019, 04:48 PM
Indeed bahamut cars doesn't go in depth enough, I found schematics of the braking system involving the ABS actuator but nothing that definitively describes which pipe goes where.
My only suggestion is to start digging and follow the brake lines to the individual wheels.
Talisker
10-01-2019, 04:48 PM #3
Fozzy
11-01-2019, 12:48 AM
I think you may have to re-plumb the abs output. Chances are that the two supply lines into the actuator are diagonally split on the output as a safety feature. To get fronts only I think you will need to swap one front and rear output from the actuator.
Edited 22-02-2012, 10:23 AM by Fozzy.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
11-01-2019, 12:48 AM #4
11-01-2019, 09:17 AM
Think I'll put a little water in the cylinder then push it through to the abs and work it out that way
Your idea seems sensible though pete, thanks
11-01-2019, 09:17 AM #5
Talisker
11-01-2019, 09:25 AM
Can't you just undo the pipes from the abs actuator then wind in the front caliper pistons and see which pipes p**s fluid?
Talisker
11-01-2019, 09:25 AM #6
11-01-2019, 09:32 AM
No cause the systems empty at the mo with my rebuild
11-01-2019, 09:32 AM #7
Talisker
11-01-2019, 11:17 AM
Aha, I see the problem inherent with your situation.
Talisker
11-01-2019, 11:17 AM #8
11-01-2019, 11:21 AM
I'll try it with just air see if I can figure it out
11-01-2019, 11:21 AM #9
Views 277
16-06-2022, 03:51 AM
Views 366
12-12-2020, 10:51 AM
Last Post by phaebo
Views 443
16-10-2020, 07:33 AM
Last Post by Mr-cth
Views 541
23-03-2020, 04:20 PM
Views 764
11-11-2019, 01:41 AM
Views 608
30-07-2019, 08:00 AM
Views 807
13-04-2019, 12:57 PM
Last Post by LEXOB
Views 781
01-07-2018, 01:41 AM
Last Post by E55EX_RACER
Views 264
28-12-2017, 05:24 PM
Last Post by LEX11S
Views 705
24-12-2017, 07:45 AM
Last Post by aaronabbott
