JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Brake caliper seal replacement
rob
11-12-2020, 01:22 AM
Had a sticky piston on the LH side resulting in pulling to the right, found the dust boot was damaged allowing the piston to stick.
Freed it using silicon grease but only a temp fix so...
[Image: zybehu5e.jpg]
3 seal sets £35
New brembo front discs and mintex pads for £90 and bit of my time.
Seals are easy to change, you might have problems getting the pistons out so go to a garage and ask them to remove the pistons with an air gun though you could prob pull them out with a set of grips.
Tip: grab the dust boot and pull, the circlip will come out also, use a pick to remove the main hydraulic seal and clean the recess.
I took the oportunity to totally strip and clean mine but no need to go that far.
For rebuild you use caliper grease 08887-01206 at about £8 for a tube. Lube the pistons and seals and a squirt more in the dust cap.
rob
11-12-2020, 01:22 AM #1
3 seal sets £35
rob
12-12-2020, 06:30 AM
[Image: e4u7u7eh.jpg]
[Image: pe3ytaby.jpg]
[Image: 2u3ypady.jpg]
[Image: pe7ureta.jpg]
[Image: 4yra3u2a.jpg]
[Image: ve8etygy.jpg]
[Image: u9e5eqem.jpg]
[Image: syzevate.jpg]
Job done. Big Grin
rob
12-12-2020, 06:30 AM #2
Job done. Big Grin
12-12-2020, 07:16 AM
looking good mate
12-12-2020, 07:16 AM #3
looking good mate
rob
12-12-2020, 08:14 AM
Cheers, going to the workshop later to torque the bolts that hold the 2 halfs of the caliper. .. remember to use thread lock!
Once they are installed ill give everything another coat of paint and install them next week when I have more time. Using the yaris in between.
[Image: myvuvage.jpg]
rob
12-12-2020, 08:14 AM #4
12-12-2020, 08:49 AM
it is top work mate Smile
12-12-2020, 08:49 AM #5
phaebo
12-12-2020, 10:51 AM
Wow awesome write up!
Great way to slide the piston back in. Always struggeling getting the piston back in. But the way you show with the piece of plastick paper is a great way to do the job thanks!
phaebo
12-12-2020, 10:51 AM #6
Views 275
16-06-2022, 03:51 AM
Views 437
16-10-2020, 07:33 AM
Last Post by Mr-cth
Views 534
23-03-2020, 04:20 PM
Views 739
11-11-2019, 01:41 AM
Views 601
30-07-2019, 08:00 AM
Views 803
13-04-2019, 12:57 PM
Last Post by LEXOB
Views 658
11-01-2019, 11:21 AM
Views 778
01-07-2018, 01:41 AM
Last Post by E55EX_RACER
Views 263
28-12-2017, 05:24 PM
Last Post by LEX11S
Views 699
24-12-2017, 07:45 AM
Last Post by aaronabbott
