JapCarForum Car Manufacturers Lexus/Toyota Is300 to j160 manual conversion
john wan
16-11-2022, 12:01 AM
Hi looking to get real soon an is300 but I'm not wanting a boaring auto so as can't get manual over here I'm going to have to convert it , so I wanna try using the is200 j160 box now I know they don't mount up as bolt holes are different so will need a spacer plate or adaption to the box my question is has anyone got any info on this being done? :thumbup:
john wan
16-11-2022, 12:01 AM #1
FOSSIL FUELS
Moderator
892
16-11-2022, 01:57 AM
I have been looking in to it as well....
There are 2 or 3 options with manual conversions.
1) BMW 330d box with a custom bell housing.
2) 350z get rag 6 speed with bell housing converter.
3) Standard TOYOTA swaps... W58, R154, Get rag 6 speed out of a supra.
[Image: Supra-logo-toyota-supras-119417_1569_512...duxjro.jpg]
Toyota Supra Aero Top... In 202 Black and 18" GOLD & Chrome's with a BGW Wink
FOSSIL FUELS
16-11-2022, 01:57 AM #2
16-11-2022, 02:01 AM
You will also need to do something with the prop, as the is200 and is300 diffs are not the same. I'd also try and find an is300 with a 3.7 diff rather than the 3.9 as your gearing will be far too aggressive for the 2j otherwise.
Edited 28-12-2015, 11:36 AM by el_bandido.
16-11-2022, 02:01 AM #3
john wan
16-11-2022, 02:30 AM
Agressive is good ha ha ha ha yeah know about the prop this is why I wanna try with the is200 box an then use manual prop from one failing that there's a place in Cambridge that will make them just need corosponding ends
john wan
16-11-2022, 02:30 AM #4
16-11-2022, 03:25 AM
Is the car primarily a road car?
16-11-2022, 03:25 AM #5
john wan
16-11-2022, 06:19 AM
Yeah it will be but I like cars that can also be fun to play (skid about in)
john wan
16-11-2022, 06:19 AM #6
john wan
21-11-2022, 03:01 AM
So parts I'll need real free to chip in if I've missed anything
Gearbox (already got one lined up)
Clutch and acceleration pedles
Clutch master cylinder
Clutch slave cylinder
Clutch lines
Clutch oil
Gearbox oil
Fly wheel and bolts
Spigot bearing
Gearbox bolts
Adapter plate
Starter motor ( already have)
Propshaft
Gear stick gator an surround an metal cover plate an bolts
john wan
21-11-2022, 03:01 AM #7
Clutch lines
Clutch oil
Gearbox oil
Fly wheel and bolts
Spigot bearing
Gearbox bolts
Adapter plate
Propshaft
21-11-2022, 03:53 AM
Brake pedal is different as well.
You'll need something to fool the auto ecu, or a manual ecu from America
21-11-2022, 03:53 AM #8
21-11-2022, 03:55 AM
Gearbox mount
21-11-2022, 03:55 AM #9
Gearbox mount
john wan
21-11-2022, 08:31 AM
Ah box will come with mount I think good shout though I think I might just get a full pedle set up just to be sure,
I've found a couple of 2jz ge manual ecu in England but the manual swap I found on line the guy just used the auto ecu just did some cable snipping an connecting
john wan
21-11-2022, 08:31 AM #10
Views 397
03-02-2023, 08:03 AM
Last Post by theblitz6666
Views 969
30-01-2023, 06:58 AM
Last Post by Millo73
Views 241
28-12-2022, 11:55 AM
Views 284
23-12-2022, 09:27 AM
Last Post by phaebo
Views 598
21-07-2022, 11:51 AM
Last Post by MichaelTTE
Views 295
27-02-2021, 04:08 AM
Last Post by rock on
Views 259
26-01-2021, 11:08 AM
Views 742
04-07-2018, 04:50 AM
Last Post by uncle bob
Views 1,781
20-08-2017, 10:13 PM
