JapCarForum Car Manufacturers Lexus/Toyota is300 exhaust fit is200
beamstezza
21-12-2022, 03:06 PM
Hi lads quick question for ye .
will an is300 exhaust from down pipe back fit an is200?
beamstezza
21-12-2022, 03:06 PM #1
phaebo
21-12-2022, 11:52 PM
The manifold is diffrent but the rest of the exhaust will fit.
Only thing is the o2 sensor holes are diffrent. If you want to fit an is300 exhaust on an is200 you need to weld a o2 sensor bung.
It is also possible that an is300 exhaust will stick out further behind the rear bumper. Because usa is300 have longer rear bumper.
phaebo
21-12-2022, 11:52 PM #2
beamstezza
22-12-2022, 06:06 AM
phaebo The manifold is diffrent but the rest of the exhaust will fit.
Thanks mate the 02 bung i can sort its a decat pipe iv been looking at and i heard they would fit but i wanted to be sure
beamstezza
22-12-2022, 06:06 AM #3
phaebo
23-12-2022, 09:27 AM
If you only take the y-pipe it will fit no problem. The oxygen sensor is in the mid pipe.
But if it is without a cat you get check a check engine light.
Put this thing between you exhaust and your oxigen sensor and the light stays off.
http://fullcartuning.nl/blox-racing-chec...or-adapter
phaebo
23-12-2022, 09:27 AM #4
Views 506
06-01-2024, 08:26 AM
Last Post by bigdave1701
Views 327
09-10-2023, 03:21 PM
Views 329
04-10-2023, 12:38 PM
Last Post by CrocodileHunter
Replies 22
Views 1,184
27-07-2023, 11:45 AM
Replies 52
Views 2,524
14-07-2023, 09:41 PM
Last Post by Mr_Woods
Views 711
25-05-2023, 06:58 AM
Views 389
24-05-2023, 01:50 PM
Last Post by ViperTheLex
Views 619
20-05-2023, 07:02 AM
