JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Changing suspension?
Andy-R.
22-09-2016, 11:21 AM
How easy is it to change the suspension for OEM replacment? I know it's a straight swap but whats involved, is it just a case of undo a few bolts at the top and then swing the leg out of the bottom once thsose bolts etc. are out of the way? or is it far more involved than that? cheers:biggrin:
[Image: Lf9Nl.jpg]
Andy-R.
22-09-2016, 11:21 AM #1
[Image: Lf9Nl.jpg]
22-09-2016, 11:23 AM
Which bits of the suspension are you changing ? Just the shocks and keeping the springs ? Changing shocks and springs for coilovers ? Changing suspension arms etc ?
22-09-2016, 11:23 AM #2
Andy-R.
22-09-2016, 11:29 AM
Shocks and springs, just want to drop the shocks out with the springs still on and put new ones in.
[Image: Lf9Nl.jpg]
Andy-R.
22-09-2016, 11:29 AM #3
[Image: Lf9Nl.jpg]
aaronabbott
22-09-2016, 11:37 AM
fairly easy mate,the only prob you'll have is on the rear when you'll have to put a bit of weight on the rear hub to allow you some more room to move the shock assembly out,
i changed all mine when i put my coilovers on in just over 2 hours and that was taking my time :thumbup1:
aaronabbott
22-09-2016, 11:37 AM #4
Andy-R.
23-09-2016, 12:43 AM
Cheers:biggrin:
[Image: Lf9Nl.jpg]
Andy-R.
23-09-2016, 12:43 AM #5
Cheers:biggrin:
[Image: Lf9Nl.jpg]
23-09-2016, 12:54 AM
Found when i did mine a few times, that if you drop the anti roll bar lower drop link bolt out it gives you a bit more freedom on the rears, and makes life a bit easier :thumbup1:
You got some new ones to go on then mate? or you still thinking of coilovers/ lowering springs for the future? :biggrin:
23-09-2016, 12:54 AM #6
Andy-R.
23-09-2016, 01:18 AM
Bandit Found when i did mine a few times, that if you drop the anti roll bar lower drop link bolt out it gives you a bit more freedom on the rears, and makes life a bit easier :thumbup1:
Still want coilcovers but might have something lined up for the time being:wink: nothing major tho.
[Image: Lf9Nl.jpg]
Andy-R.
23-09-2016, 01:18 AM #7
[Image: Lf9Nl.jpg]
23-09-2016, 01:27 AM
Cool, they are quite straight forward to swap over but just need a bit of brute force at some points, and easier to do on a lift if you can get to use one? :thumbup1:
23-09-2016, 01:27 AM #8
Andy-R.
23-09-2016, 01:31 AM
Cheers buddy.:thumbup:
[Image: Lf9Nl.jpg]
Andy-R.
23-09-2016, 01:31 AM #9
[Image: Lf9Nl.jpg]
Andy-R.
24-09-2016, 01:20 AM
DJ Wozza Lil' Tony @WIM did mine in 45 mins from start to finish, but obviously he had a lift and air tools.
And knowledge:tongue_smilie:
[Image: Lf9Nl.jpg]
Andy-R.
24-09-2016, 01:20 AM #10
[Image: Lf9Nl.jpg]
Views 298
03-11-2020, 07:28 AM
Last Post by argyle dan
Views 337
12-03-2020, 10:38 AM
Last Post by James S
Views 681
04-06-2019, 06:03 AM
Views 485
07-04-2019, 09:04 AM
Views 560
11-07-2018, 10:12 PM
Views 1,112
02-02-2018, 06:37 AM
Last Post by ekme
Replies 22
Views 1,456
21-05-2017, 10:46 AM
Last Post by ormi
Views 629
17-01-2017, 12:44 AM
Views 487
06-10-2016, 12:52 PM
