JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza front fog alignment - settings?
rob
22-12-2016, 08:52 AM
Hi,
Had the MFK Motorfahrzeugkontrolle (swiss MOT) today and the lovely person:mad: failed me on the LH front fog light alignment, he said it was pointing into the sky but when i look at the beam against a wall LH and RH are the same height.
I had a look in the workshop manual but it only shows the adjustment. I didnt see him use a beam aligner on the fogs only the headlights.
Does anyone know the height/distance the beam should point?
Ormi - any ideas?
rob
22-12-2016, 08:52 AM #1
Hi,
Ormi - any ideas?
22-12-2016, 09:35 AM
Rob could he not adjust it for you?
I can not find any details of how you measure the beam
22-12-2016, 09:35 AM #2
rob
22-12-2016, 10:01 AM
no mate, its not like the UK where u go to a garage, over here it is run by the council, all they do is test and nothing else. Some places are easy, some are a right pain in the ****..... like the one i had to go to.
rob
22-12-2016, 10:01 AM #3
22-12-2016, 10:04 AM
Will a Lexus dealer set them for you?
Have you changed from the standard bulbs Rob?
22-12-2016, 10:04 AM #4
rob
22-12-2016, 10:12 AM
noope all standard, they didnt coomplain when i imported the car and nothing has changed, i reckon the bloke was being a knobber as im a foreigner.... not unusual for swiss people! yes the lex garage will do it but they will charge about £100 for the pleasure. Ill pop to a local garage where i had the emissions test and slip him for cash to stamp off the sheet i think!.
I also had a look and cant find anything about foglight alignment.
rob
22-12-2016, 10:12 AM #5
22-12-2016, 10:16 AM
Silly question, but do the fog lights have to be working as part of the Swiss "MoT" ? Don't think they're tested here. Could you just not point them both right down as part of the adjustment ?
I don't remember seeing anything about foglight adjustment in the manual either (where they need to point to, I mean).
22-12-2016, 10:16 AM #6
22-12-2016, 10:17 AM
i didnt think you could adjust the fogs but i may be wrong lol
22-12-2016, 10:17 AM #7
22-12-2016, 10:19 AM
Rabster i didnt think you could adjust the fogs but i may be wrong lol
You can, they adjust for vertical alignment.
22-12-2016, 10:19 AM #8
22-12-2016, 10:24 AM
When i worked at the Toyota factory and the BMW mini factory, we used to set the fog lights up at around 4" below the dip beam cut off line ? (if that makes sense?)
Dip beam[SIZE="5"][COLOR="Red"] cut off> \____ \____
Fogs here >>> ____ ____[/COLOR][/SIZE]
Like this Dodgy pic approx 4" below :laugh:
22-12-2016, 10:24 AM #9
22-12-2016, 10:25 AM
Rob what happens if you remove the fogs would this be allowed in Switzerland.
I only too well no what you mean about how the Swiss treat foreigners funny sods...
22-12-2016, 10:25 AM #10
Views 233
01-07-2020, 04:42 AM
Views 722
02-08-2019, 08:39 AM
Last Post by jasons
Views 321
28-07-2019, 04:57 AM
Last Post by Matt_C
Views 346
19-07-2019, 12:48 PM
Last Post by Chris0121
Views 921
01-04-2019, 04:02 AM
Last Post by lookatmybiceps
Views 384
15-01-2019, 05:15 AM
Last Post by avi_444
Views 1,289
28-11-2018, 10:22 AM
Last Post by sprinter2012
Views 408
03-09-2018, 02:06 PM
Last Post by ydooh
Views 298
01-09-2018, 11:23 AM
