JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Caliper Sliding Pin
Caliper Sliding Pin
Caliper Sliding Pin
TommyH
04-05-2018, 06:38 AM
Was wondering if it's ok to use coppeer slip grease on your caliper sliding pins or should i have used something else ?
Thanks
TommyH
04-05-2018, 06:38 AM #1
Thanks
Fozzy
04-05-2018, 07:08 AM
Dont use copper grease. It is too abrasive and will cause too much wear. Ideally you want a silicone based grease
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
04-05-2018, 07:08 AM #2
TommyH
04-05-2018, 08:35 AM
$hit, iv'e already used copperslip, will it be ok to take them back out, clean them and re-grease them ?
Thanks
TommyH
04-05-2018, 08:35 AM #3
Thanks
Fozzy
04-05-2018, 09:20 AM
Yeah that will be fine. Im guessing you havent had it like that for too long. Clean them off and regrease with silicone grease. This is often sold as a motorcycle lubricant, but just go to a motor factors and ask for silicone grease
Fozzy
04-05-2018, 09:20 AM #4
TommyH
04-05-2018, 09:57 AM
Thanks for the advice Hurricane, much appreciated.
TommyH
04-05-2018, 09:57 AM #5
Views 804
12-12-2021, 04:40 PM
Last Post by phaebo
Views 1,037
16-10-2021, 01:21 PM
Last Post by Mr-cth
Views 1,955
26-04-2018, 05:01 PM
Last Post by TommyH
