JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Brake Caliper
Brake Caliper
Brake Caliper
TommyH
25-04-2017, 06:34 AM
Hi folks, ive just heard a rubbing noise coming from the passenger side front wheel. On further inspection ( touching the disc and scolding my finger) it looks like the front caliper is sticking on.
Would i be able to free the caliper by just pushing it back in or is their something else i need to do ie getting a new one or refurbing the old one ?
Thanks.
TommyH
25-04-2017, 06:34 AM #1
Thanks.
25-04-2017, 06:44 AM
If its sticking on it prob needs refurbing mate,
25-04-2017, 06:44 AM #2
TommyH
25-04-2017, 06:48 AM
S**t, wasn't what i wanted to hear :Sulk: Thanks Stav.
TommyH
25-04-2017, 06:48 AM #3
25-04-2017, 06:51 AM
You can do it yourself, its a matter of taking if off, popping the pistons out cleaning them up and putting either them back in, or new ones, both ways will need new sales. Its not too hard to do
25-04-2017, 06:51 AM #4
TommyH
25-04-2017, 06:54 AM
Im going to nip out and have a look. Do you know if halfords sell seals mate ?
TommyH
25-04-2017, 06:54 AM #5
25-04-2017, 08:00 AM
No mate, youll have to find some on the net i reckon
25-04-2017, 08:00 AM #6
25-04-2017, 08:26 AM
you can get them on ebay from big red
25-04-2017, 08:26 AM #7
TommyH
25-04-2017, 08:46 AM
Thanks for the info lads, i'll have a wee look.
TommyH
25-04-2017, 08:46 AM #8
TommyH
26-04-2017, 04:57 AM
When pushing the pistons back in, should you loosen the bleeding nipple or open the brake fluid resoviour or both ?
TommyH
26-04-2017, 04:57 AM #9
Fozzy
26-04-2017, 05:11 AM
I would take the caliper off the car. It will make your life much easier. If you clamp the hose before unbolting it, you will not loose too much fluid, and you will only need to bleed that one caliper when you refit it
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
26-04-2017, 05:11 AM #10
Views 275
16-06-2022, 03:51 AM
Views 365
12-12-2020, 10:51 AM
Last Post by phaebo
Views 437
16-10-2020, 07:33 AM
Last Post by Mr-cth
Views 535
23-03-2020, 04:20 PM
Views 740
11-11-2019, 01:41 AM
Views 602
30-07-2019, 08:00 AM
Views 803
13-04-2019, 12:57 PM
Last Post by LEXOB
Views 658
11-01-2019, 11:21 AM
Views 778
01-07-2018, 01:41 AM
Last Post by E55EX_RACER
Views 263
28-12-2017, 05:24 PM
Last Post by LEX11S
