JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Lexus IS200 Brake Pad Clip
TommyH
06-05-2017, 12:26 AM
Hi guys, i took my front pads out yesrerday to give them a clean and put coppersilp on them as they were making that clunking noise AGAIN. When i took the inside pad out i noticed the little clip that holds the pad into the caliper was actually attached to the pad with what looks like a kind of pot rivet. Is this the way its suppose to be ? I thought the clips should go into the caliper ?
[IMG][Image: SNV33374.jpg][/IMG]
TommyH
06-05-2017, 12:26 AM #1
TommyH
06-05-2017, 09:49 AM
Bump Confusedad:
TommyH
06-05-2017, 09:49 AM #2
Bump Confusedad:
06-05-2017, 09:53 AM
That's not a clip to hold the pad in place - it rubs on the disc when the pad surface has got low and squeals at you to let you know you need new pads Smile
Edit: Ahh ****, no it isn't, it's on the wrong side. I'll shut up now!
06-05-2017, 09:53 AM #3
TommyH
06-05-2017, 10:15 AM
So Gord, when you buy new pads, they come with the clip attached ?
TommyH
06-05-2017, 10:15 AM #4
TommyH
06-05-2017, 10:25 AM
Thanks mate.
TommyH
06-05-2017, 10:25 AM #5
Thanks mate.
widnes_is200
06-05-2017, 11:02 AM
sorry tommy ive been very busy with hospitals havent fogot that spring, the clips u need too be checking are the ones that the pads go into , theres 1 top and bottom with a little spring in them that hold the pad tight in the caliper mate, (will post the other promise)
widnes_is200
06-05-2017, 11:02 AM #6
TommyH
06-05-2017, 11:07 AM
No probs Dave, i know youv'e had other things to deal with mate, just when you can manage.
As for the top clip, it looks like thats missing also Confusedad: Wonder if these can be bought seperately or you have to buy the whole set ?
TommyH
06-05-2017, 11:07 AM #7
dodgydave
06-05-2017, 11:08 AM
Now that's weird. I've seen these on some pads when I've replaced them, maybe the wife's or daughter's Yaris I think but when I had my brakes apart the other week to paint the callipers there's wasn't any of these on the pads. The pads had Toyota stamped on them :blink:
dodgydave
06-05-2017, 11:08 AM #8
dodgydave
06-05-2017, 11:18 AM
This is what the clips look like
[Image: 4700196391_1c2a3e915c_b.jpg]
and this is my pad and shims
[Image: 4700837622_c0d435751b_b.jpg]
dodgydave
06-05-2017, 11:18 AM #9
TommyH
06-05-2017, 11:29 AM
Thanks Dave, im defo missing one top (RH side looking at pic) clip and i dont have the shims with the slots cut out, i have the other solid ones.
TommyH
06-05-2017, 11:29 AM #10
Views 275
16-06-2022, 03:51 AM
Views 365
12-12-2020, 10:51 AM
Last Post by phaebo
Views 437
16-10-2020, 07:33 AM
Last Post by Mr-cth
Views 535
23-03-2020, 04:20 PM
Views 740
11-11-2019, 01:41 AM
Views 454
10-08-2019, 10:35 AM
Views 602
30-07-2019, 08:00 AM
Views 682
19-06-2019, 11:01 AM
Last Post by Mr Reman
Views 803
13-04-2019, 12:57 PM
Last Post by LEXOB
Views 524
06-03-2019, 12:19 PM
