JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza replacing fuel pump.
07-05-2017, 10:46 AM
about to do this but is there a hatch under the back seat to do this or do i need to drop the tank.
thanks
07-05-2017, 10:46 AM #1
thanks
iano21
07-05-2017, 11:36 AM
well,
done this already and put in a walbro fuel pump. .
just lift the seat it clips out on front and then lifts out. see row of studs take them out and disconnect wire from top of pump that goes through the pump! this leaves the big black nut, hard to loosen (while trying not to break it ha) but i used the big wrench i had lol.
once that nut off lift up pump slightly and there is a rubber pipe you need to disconnect from the pump with a spring clip on it! then with that off it pulls out tilting to one side to allow fuel gauge to come on. .
then repeat in reverse lol. . hope that helps
ian
iano21
07-05-2017, 11:36 AM #2
well,
ian
07-05-2017, 11:49 AM
yer man it does. i had been told you might be able to take it out from the top but was not sure. great will fix it tomorrow
07-05-2017, 11:49 AM #3
iano21
07-05-2017, 12:07 PM
no problem. .
hey sorry was thinking of my other car got the two mixed up ha. was just looking at it. . there is no big nut on it ha its way easier. also the pipes on the top need to be disconnected you will see the clips on them not a big job!!
would not mind only took it in and out few times ha. all rest is right just not the big nut just looked at it sorry!!
ian
iano21
07-05-2017, 12:07 PM #4
no problem. .
ian
08-05-2017, 10:15 AM
Jay take some pictures for everyone!
08-05-2017, 10:15 AM #5
08-05-2017, 10:16 AM
Jay we need loads of pictures of your new build mate
08-05-2017, 10:16 AM #6
08-05-2017, 12:49 PM
will do mate. just saving it till the end
08-05-2017, 12:49 PM #7
09-05-2017, 08:21 AM
got the pics and will post up a bit of a how to later
09-05-2017, 08:21 AM #8
Views 224
10-06-2020, 05:52 AM
Views 206
19-03-2020, 06:22 AM
Last Post by ozzie b
Views 288
08-09-2019, 02:59 AM
Last Post by MKT222
Views 293
31-08-2018, 11:41 AM
Last Post by Fozzy
Replies 56
Views 3,073
18-04-2018, 10:32 AM
Last Post by karlp
Views 315
09-02-2018, 03:38 PM
Last Post by Phil01
Views 296
18-06-2017, 08:52 AM
Views 400
08-06-2017, 09:49 AM
Last Post by Andy-R.
