JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza O rings on water pump.
Andy-R.
06-06-2018, 12:51 PM
How easy are the O rings to change on the water pump I think I have a very slight leak from them, is it worth just changing the whole thing or just the rings? also how long would it take a competent mech to change the water pump?
Cheers.
[Image: Lf9Nl.jpg]
Andy-R.
06-06-2018, 12:51 PM #1
Cheers.
[Image: Lf9Nl.jpg]
06-06-2018, 12:53 PM
to change it i think you have to take the cambelt off.
look on bahamutcars for the workshop guide to see whats needed
06-06-2018, 12:53 PM #2
Andy-R.
06-06-2018, 01:01 PM
Yes mate you have to take the belt off, I can't see it taking more than an hour/hour and a half to do though with the right tools and knowledge.
[Image: Lf9Nl.jpg]
Andy-R.
06-06-2018, 01:01 PM #3
[Image: Lf9Nl.jpg]
kam05
07-06-2018, 07:53 AM
Pretty sure you don't need to remove the waterpump to change the o rings, as it is on the side of the engine and all you need is a 10mm socket to undo the 2 bolts.
Replacement 0 rings and by pass pipe is about £20 from Lexus, I think? Will have to dig out an old invoice to confirm.
kam05
07-06-2018, 07:53 AM #4
Andy-R.
07-06-2018, 04:17 PM
Where exactly is it on the engine then Kam so I can make sure it's defo from there.
[Image: Lf9Nl.jpg]
Andy-R.
07-06-2018, 04:17 PM #5
[Image: Lf9Nl.jpg]
mattlaw
08-06-2018, 01:58 PM
u can slide the water pump out from behind the belt, and no u dont need to take the water pump off to chage the bypass seals,
mattlaw
08-06-2018, 01:58 PM #6
Andy-R.
08-06-2018, 03:38 PM
Cheers so what am I looking for I know where the pump is but can't really see much else around it.
[Image: Lf9Nl.jpg]
Andy-R.
08-06-2018, 03:38 PM #7
[Image: Lf9Nl.jpg]
Views 495
10-06-2021, 11:40 AM
Views 461
31-05-2021, 06:26 AM
Last Post by reganlives
Views 521
07-09-2020, 08:48 AM
Last Post by MKT222
Views 590
31-08-2019, 05:29 PM
Last Post by Fozzy
Views 546
09-02-2019, 09:27 PM
Last Post by Phil01
Replies 22
Views 2,236
10-08-2018, 10:33 AM
Last Post by Andy-R.
Views 836
09-05-2018, 02:09 PM
Views 2,257
10-03-2018, 12:46 PM
Replies 18
Views 1,821
22-01-2018, 06:17 AM
