JapCarForum Cars, Cars, Cars! General Car Maintenance Lexus IS200 oil capacities and grades etc.....
11-07-2017, 12:41 PM
Few that i've found so thought i'd post them:thumbup1:
Manual Transmission ...
Oil capacity...1.9L (2.0qt..1.7imp qt)
Oil Type........Multi purpose gear oil API GL - 4 or GL-5
Recommended Oil Viscosity.....SAE 75W-90
Automatic Transmission...
Fluid Capacity...Drain and Refill...2.1L (2.2qt...1.8 imp qt)
Fluid Type....Automatic Transmission Fluid Type T -IV or Equivalent
Differential..
Oil Type...Hypoid Gear Oil API GL-5
Oil Viscosity.. Above 18 degree's C... SAE 90
Below 18 degree's C... sae 80w or SAE 80W-90
Clutch...
Pedal Freeplay....5 - 15mm
Fluid Type..........SAE J1703 or FMVSS No. 116 Dot 3
Brakes...
Fluid Type....SAE J1703 or FMVSS No. 116 DOT 3
Steering
Power Steering Fluid Type...Automatic Transmission Fluid Dextron II or III
Oil Capacity..
Manual Transmission... (Drain and Refill)
With Filter...4.2L (4.4qt - 3.7 imp qt)
Without Filter..4.0L (4.2qt - 3.5 imp qt)
Automatic Transmission..(Drain and Refill)
With Filter... 4.1L (4.3qt - 3.6 imp qt)
Without Filter...3.9L (4.1qt - 3.4imp qt)
Coolant...
Coolant Capacity..7.1 Litres (7.5 qt - 6.2 imp qt)
Coolant Type...Toyota Long Life Coolant or Equivalent
(Do not use Alcohol Type Antifreeze or Plain Water Alone!!)
Fuel...
Octane Rating 95 or Higher
Fuel Tank Capacity...70L (18.5gal - 15.4 imp gal)
Spark Plugs..
Denso.................SK20R11
Denso upgrade.....IK20
NGK....................IFR6A11
Supercharged IS200 Plugs...
Denso.... IK22
NGK ...... BKR7EIX
Gap Size.....1.1mm (0.043in)
Any more then add them to the thread Guys and Girls :thumbup1:
Edited 24-08-2010, 12:30 AM by Bandit.
11-07-2017, 12:41 PM #1
Differential..
Clutch...
Brakes...
Steering
Oil Capacity..
Coolant...
Fuel...
Spark Plugs..
Denso.... IK22
NGK ...... BKR7EIX
11-07-2017, 12:49 PM
Very useful info mate, Dean will be pleasedSmile
11-07-2017, 12:49 PM #2
11-07-2017, 12:50 PM
Was bored mate :laugh:
11-07-2017, 12:50 PM #3
Jambo
11-07-2017, 12:51 PM
Ahah, i bet dean has a big smile on his face.
Thats an excellent find bandit, Well done! +rep
Latest Meets
Ace Cafe 16/10/10,
Jambo
11-07-2017, 12:51 PM #4
Latest Meets
Ace Cafe 16/10/10,
11-07-2017, 12:53 PM
See what people can get up to when they're bored? Think minewas more amusing though Tongue
11-07-2017, 12:53 PM #5
11-07-2017, 12:54 PM
Cheers matey, its all out of the lexus is200 handbook so just thought i'd add it here :thumbup1:
Ooooohhh look i now have 4 green REP boxes :w00t::w00t:
11-07-2017, 12:54 PM #6
11-07-2017, 01:28 PM
nice one bandit, rep added!
11-07-2017, 01:28 PM #7
Andy-R.
12-07-2017, 10:21 AM
Good work Chris.
You can also use DENSO IK20 Spark plugs, and I think it's IK22's for Supercharged.
[Image: Lf9Nl.jpg]
Andy-R.
12-07-2017, 10:21 AM #8
Good work Chris.
[Image: Lf9Nl.jpg]
12-07-2017, 02:57 PM
Marsdendean Cheers bandit Rep Added.
Maybe you could add how much the Diff takes, as that seams to be the only bit of service data that is missing?
Will try and find the diff quantity mate, :thumbup1:
12-07-2017, 02:57 PM #9
09-09-2017, 12:26 PM
Diff capacity = 1.0 L for open diff, 1.05 L with LSD.
09-09-2017, 12:26 PM #10
Views 339
09-11-2023, 11:04 AM
Last Post by Keeperlit19
Views 695
28-06-2022, 04:42 AM
Last Post by MichaelTTE
Views 963
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,470
22-07-2021, 03:46 AM
Last Post by simon87
Views 592
17-03-2021, 09:57 AM
Last Post by iceman
Views 936
17-02-2021, 08:43 AM
Views 826
11-02-2021, 11:27 AM
Views 862
28-01-2021, 06:18 AM
Last Post by 1374lee
Views 1,042
27-01-2021, 04:28 PM
Views 924
27-01-2021, 01:37 AM
