JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Door mirrors
Door mirrors
Door mirrors
24-09-2017, 12:22 PM
Has anyone taken apart a door mirror on an IS200/300 ? (or Altezza)
My problem is this. A while back, the up/down adjustment on one of my mirrors stopped working. I'm pretty sure that the motor burnt out due to water ingress into the car causing the motor to permanently try to adjust.
Anyway, I got a new mirror assembly from eBay. However, the body-coloured section (though the right colour for my car) is more scratched than my own one. So rather than swap the whole assembly, I'd like to do a mix and match.
On the existing door mirror, I took the mirror glass off, but it doesn't look straightforward to extract/replace the up/down motor, and the repair idea seems to be to swap the whole assembly (based on the workshop manual, and the fact that there aren't individual part numbers for the components).
What I might be able to do is swap the whole assemblies over. But then to swap back the body-coloured bit from my own car.
Has anyone taken this body-coloured bit off ? It looks to me like it probably pops out, but I thought I would ask before trying it out, since I seem to remember that someone might have tried this before.
24-09-2017, 12:22 PM #1
24-09-2017, 12:41 PM
im sure you can just pop the coloured bit off mate but never tried it
24-09-2017, 12:41 PM #2
24-09-2017, 01:18 PM
look in the workshop guide for my mirror blinkers mate there is all you need in that post
24-09-2017, 01:18 PM #3
24-09-2017, 01:24 PM
The body coloured bit is held on by 3 or 4 screws.
If you pop the mirror itself off you can see them, just unscrew and away it comes.
24-09-2017, 01:24 PM #4
24-09-2017, 01:38 PM
This is Jay's mirror topic mate, CLICK ME?
24-09-2017, 01:38 PM #5
24-09-2017, 01:42 PM
Mine are DEFINITELY screwed on so be careful
24-09-2017, 01:42 PM #6
24-09-2017, 01:47 PM
Just found this some place too..
Quote:Lexus IS200/300 Mirror Glass Removal
1) Move the mirror all the way up.
2) Insert a screw driver behind it and pry it upwards. This will release the lower portion of the mirror
3) Keep moving the mirror up and the upper section of the mirror should also come loose.
4) unplug the heater wires
5) There are 3 philips screws that hold the mirror cover in place (you should be able to see which ones they are).
6) Replace the mirror cover.
7) Putting it back is just the reverse
Smile
24-09-2017, 01:47 PM #7
Smile
Fry-Up
24-09-2017, 02:02 PM
depends on the year of the car, pre 2001/2 (?) were screwed on, newer ones just clipped on
Fry-Up
24-09-2017, 02:02 PM #8
25-09-2017, 12:28 AM
Cool, thanks guys, just what I wanted :thumbup:
Hopefully the combination of the new mirror unit plus my original backing will be just what I need :biggrin:
25-09-2017, 12:28 AM #9
Views 230
23-01-2021, 07:58 AM
Views 331
30-03-2019, 11:33 AM
Last Post by posty
Views 569
24-11-2018, 04:03 AM
Replies 36
Views 1,799
14-11-2018, 01:40 PM
Last Post by jomo
Views 651
06-04-2018, 10:24 AM
Views 683
05-01-2018, 10:57 AM
Views 1,137
28-11-2017, 06:08 AM
Views 426
26-11-2017, 01:06 PM
Replies 18
Views 881
15-04-2017, 11:41 AM
Last Post by Bandit
