JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Hazard lights and drivers door open shut sensor
James S
26-11-2017, 09:10 AM
My hazard lights are not working. Sad
Does anyone know where they are controlled from? Is it from the climate control box?
Also, I think the drivers door open and shut sensor is a bit broken. As the inside light doesn't come on with the drivers door (works fine with the others) and the auto headlights don't go off when you open the drivers door.
Does anyone know where the sensor/switch is? :thumbup:
Can't be bothered taking it back to garage unless its an expensive job.
James S
26-11-2017, 09:10 AM #1
26-11-2017, 09:28 AM
The sensor is on the side of the door frame opposite side to the hinge.
The hazards are from the climate control i believe. look on Bahamutcars for the wiring diagram
26-11-2017, 09:28 AM #2
Phil01
26-11-2017, 09:31 AM
door open switch is prob a bad earth, but sometimes known for switch to fall apart
Phil01
26-11-2017, 09:31 AM #3
James S
26-11-2017, 10:03 AM
Wicked thanks guys, its usually at the same side as th hinge. Smile
Got a few little things to have a look at tomorrow, so will check it out then.
Could anyone point me in the right direction for some wheel nuts? LOL! I am a bit lost as to which ones I need for my TTE Corse wheels. :confused:
James S
26-11-2017, 10:03 AM #4
26-11-2017, 03:28 PM
the same ones your using the now mate...
26-11-2017, 03:28 PM #5
James S
27-11-2017, 12:25 AM
They won't fit. Sad
They need a special chamford nut, but not sure which ones will fit.
James S
27-11-2017, 12:25 AM #6
They won't fit. Sad
27-11-2017, 01:02 AM
You'll need M12x1.5 wheel nuts mate, if you need the cone fitting and not the lexus flat fitting? something like these CLICK ME?
Have a search though mate as you might find some better ones :thumbup1:
Edited 08-01-2011, 10:41 AM by Bandit.
27-11-2017, 01:02 AM #7
James S
27-11-2017, 01:13 AM
Nice one, thank you mate
James S
27-11-2017, 01:13 AM #8
James S
27-11-2017, 01:24 AM
On the standard sat nav, can you stop that warning coming up when you switch the car on?
James S
27-11-2017, 01:24 AM #9
27-11-2017, 01:35 AM
James S On the standard sat nav, can you stop that warning coming up when you switch the car on?
no.
27-11-2017, 01:35 AM #10
no.
Views 1,175
02-11-2022, 10:55 AM
Views 177
23-01-2021, 07:58 AM
Views 159
07-10-2020, 01:46 AM
Last Post by Stoney
Views 286
23-10-2019, 06:59 AM
Last Post by reganlives
Views 309
19-09-2019, 08:41 AM
Last Post by jomo
Views 461
12-09-2019, 02:13 PM
Last Post by IanH
Views 502
15-05-2019, 05:06 PM
Last Post by Mr Reman
Views 303
10-05-2019, 04:47 AM
Last Post by Fry-Up
Views 285
09-05-2019, 12:39 PM
Last Post by jasons
