JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Door Light Problem
Door Light Problem
Door Light Problem
TommyH
04-01-2018, 11:10 PM
Hi folks, got into the car this morning and noticed the drivers door marker light is staying on, even when i lock the doors. I've checked the door switches and they're fine.
I had the dreaded headlights staying on, last week, but i dried everything out, re-sealed the windscreen and all is well, until this problem.
Any idea's ?
TommyH
04-01-2018, 11:10 PM #1
Any idea's ?
04-01-2018, 11:50 PM
is the interior light staying on aswell
04-01-2018, 11:50 PM #2
TommyH
04-01-2018, 11:51 PM
No Rab, just the drivers side door marker :confused1:
TommyH
04-01-2018, 11:51 PM #3
04-01-2018, 11:53 PM
hmmm
as far as i know it gets its feed from the door switches i dont think the bonnet and boot have a link in might be worth going round and pressing all the door switches a few times in case its got a dry contact or a short maybe....
04-01-2018, 11:53 PM #4
hmmm
TommyH
04-01-2018, 11:55 PM
I only checked the front door switches mate, i'll try the rears when i finish work.
Thanks Rabster.
TommyH
04-01-2018, 11:55 PM #5
Thanks Rabster.
TommyH
05-01-2018, 01:36 AM
Strange.... The bulb that wasn't going off was an inverted LED, it was dimming when i pressed the door switch but not going off, but when i changed it to a normal buld it works. The bulb on the other door is working fine and thats the inverted LED, so now i have a blue bulb on one side and clear on the other :confused1:
TommyH
05-01-2018, 01:36 AM #6
Fozzy
05-01-2018, 01:55 AM
LED's require only a tiny current to illuminate, could be the way the curcuit is designed, but normally this problem will occur when there is a faulty earthing point.
You said that you had the damp fusebox problem. It would deffinately be worth taking a look at where the earthing points bolt to the chassis and make sure that they havent corroded a bit
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
05-01-2018, 01:55 AM #7
TommyH
05-01-2018, 02:38 AM
I'll have a look at that when i finish work, thanks Hurricane.
TommyH
05-01-2018, 02:38 AM #8
Fozzy
05-01-2018, 03:23 AM
Also, some door switches will take their earth from the screw holding them to the door pillar. Also worth removing these to check for any corrosion underneath
Fozzy
05-01-2018, 03:23 AM #9
TommyH
05-01-2018, 04:33 AM
Thanks for the info mate, i'll have a look at that also.
TommyH
05-01-2018, 04:33 AM #10
Views 387
25-06-2021, 08:14 AM
Views 233
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 177
23-01-2021, 07:58 AM
Views 399
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 164
25-12-2020, 10:57 AM
Views 240
16-09-2020, 08:21 AM
Views 514
16-09-2020, 01:57 AM
Last Post by danny1377
Views 282
30-07-2020, 12:35 AM
Last Post by Dinho
Views 226
10-06-2020, 05:52 AM
Views 235
28-03-2020, 10:39 PM
Last Post by James S
