JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Help, double din dose not fit in fascia
Pages (4): 1 2 3 4 Next
27-09-2018, 01:16 PM
What do you do if the double din cage dose not fit in to the fascia .
Got the headunit wired up but I cant get the cage to go in the fascia.
Is it ok to cut of the bottom bit of the fascia ??
27-09-2018, 01:16 PM #1
27-09-2018, 01:35 PM
Get some pics up mole we can advise better on pics
27-09-2018, 01:35 PM #2
27-09-2018, 01:50 PM
ok I cut the bottom part of ,but now the cage will not fit now because of the brackets at the bottom .
[Image: PB060001.jpg]
[Image: PB060002.jpg]
[Image: PB060003.jpg]
27-09-2018, 01:50 PM #3
27-09-2018, 02:11 PM
That facia adaptor doesn't look double din to me
27-09-2018, 02:11 PM #4
27-09-2018, 02:12 PM
it is the same one that is on the club with the post wozza and bandit did
27-09-2018, 02:12 PM #5
27-09-2018, 02:32 PM
Which bit won't fit exactly ? Sorry, I can't work out what's wrong from the pics.
27-09-2018, 02:32 PM #6
27-09-2018, 02:41 PM
The pics don't look right to me. Aren't there screw holes on the side of the new head unit ? All I can see are two long slots
27-09-2018, 02:41 PM #7
27-09-2018, 02:46 PM
If you look at the top pic, its the same one Wozza posted about but with the bottom part cut of. Now the cage dose not fit because of the brackets that get screwed in beside the TRC swithch . So I've now cut them off also :ohmy:
Next thing to do might be to cut the top or the bottom of the cage off
27-09-2018, 02:46 PM #8
27-09-2018, 02:47 PM
Just trying to think of what's going on there. Did the unit come with its own metal cage ? If so, then you shouldn't need to use that, the head unit should mount directly into the fascia adapter.
27-09-2018, 02:47 PM #9
perhaps a dose of superglue at this point Moley? :biggrin: before you cut the rest of the cage off..
Can't you fabricate something to the right size with your weldy stuff? Smile
27-09-2018, 02:47 PM #10
Views 634
13-11-2020, 09:48 PM
Views 1,274
22-03-2020, 04:25 PM
Last Post by andymunro
Views 1,631
12-04-2019, 01:40 PM
Last Post by mr-p
Replies 61
Views 8,173
26-02-2018, 07:49 PM
Last Post by redz
Views 2,843
21-09-2017, 05:25 PM
