JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Driving along...suddenly my coolant warning light lights up!
kam05
10-06-2016, 06:04 AM
Hi all,
Just got back from Manchester.
I was driving back to Ilkley from Manchester and I noticed my coolant warning light lit up on the M66! (the temp gauge stayed around the half way mark- it didn't shoot up into the red zone) I pulled over quickly as I could and popped open the bonnet. Looked at the radiator window (behind the radiator)- the coolant level was full. I didn't open the cap on the radiator (didn't fancy getting burnt with hot coolant today).
Anyone explain why this happened? Drove back to Ilkley and the coolant warning light didn't light up at all. Only thing I can think of that could have caused this is there there was a lot of rain on the motorway this morning (and driving back this afternoon as well). Could the rainwater affected the coolant sensor? The waterpump was replaced 23k ago and the themostat is working. The temp gauge always stays around the half way mark.
kam05
10-06-2016, 06:04 AM #1
Hi all,
10-06-2016, 06:59 AM
I may well be forgetting something, but I didn't think there was a coolant warning light. What did the light look like ?
10-06-2016, 06:59 AM #2
kam05
10-06-2016, 07:07 AM
its a coolant level low warning light- it looks like the oil level low light, but orange.
kam05
10-06-2016, 07:07 AM #3
alamkhan3980
10-06-2016, 07:12 AM
I think that is the oil pressure light.
alamkhan3980
10-06-2016, 07:12 AM #4
10-06-2016, 07:13 AM
What symbol is on it ? There are two oil warning lights, with the oil can on - one is for low level and the other low pressure. Sorry if I'm insulting your intelligence here, but as you sure it's not one of those, and it's the low oil level light (low oil pressure light is red I think).
10-06-2016, 07:13 AM #5
kam05
10-06-2016, 07:16 AM
Yeah, I have been told there is no low coolant light- guess I'd better check my oil level!
kam05
10-06-2016, 07:16 AM #6
10-06-2016, 07:17 AM
If it's an oil can with a wavy line under it, that's the low oil level warning light.
10-06-2016, 07:17 AM #7
kam05
10-06-2016, 07:19 AM
Yeah, it was the oil can with a wavy line under it. Thanks for your help Stevie.
kam05
10-06-2016, 07:19 AM #8
steve2009
10-06-2016, 07:52 AM
Mods:...WIM geometry setup & fine tune, K&N Air filter, Stainless steel A/C rings, Brodit phone kit, Stainless steel clock surround, B&M Shortshifter & LED Domelight, Maplight & Sun Visors, OEM Chrome exhaust tip, OEM rubber bootliner, Fan type windscreen washer jets, LS430 Side repeaters, OEM 3 bar grille, OEM cargo net, Front OEM armrest
But no oil in the sump!!!!!:ohmy:
steve2009
10-06-2016, 07:52 AM #9
11-06-2016, 10:37 PM
Did you check your oil level ? How low was it ? Just curious as to how low it needs to be to make the warning light come on (hope I don't find out through a practical example !).
11-06-2016, 10:37 PM #10
Views 404
18-10-2021, 01:34 AM
Views 520
25-06-2021, 08:14 AM
Views 305
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 547
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 205
07-10-2020, 01:46 AM
Last Post by Stoney
Views 313
16-09-2020, 08:21 AM
Views 374
30-07-2020, 12:35 AM
Last Post by Dinho
Views 326
28-03-2020, 10:39 PM
Last Post by James S
Views 510
10-03-2020, 11:17 AM
Views 304
10-03-2020, 08:16 AM
Last Post by Colin G
