JapCarForum Cars, Cars, Cars! General Car Maintenance Can fuel pumps be run dry?
05-04-2018, 11:29 PM
I want to test a fuel pump I've purchased before installing it. However I know from experiences in other trades that submersible pumps generally don't like being run dry.
On the other hand, I'd imagine that fuel pumps must be able to tolerate it a bit just in case the fuel tank is run dry (unless they have auto cut-off?)?
Advice appreciated.
05-04-2018, 11:29 PM #1
Advice appreciated.
Phil01
06-04-2018, 02:38 AM
they can be run up for a second or two mate just to test but not for a continuous time as overheating will occur and no lube to cool the bearings if it is in a dry state.
Phil01
06-04-2018, 02:38 AM #2
06-04-2018, 02:40 AM
Cool. I'm assuming the Walbro will arrive with bare wires, so I'll just hook it up to a 12v PSU for a couple of seconds to make sure it fires up.
I'm guessing though that if I installed a dead fuel pump, the car just wouldn't start - rather than doing any actual damage?
06-04-2018, 02:40 AM #3
Phil01
06-04-2018, 02:44 AM
should be ok just to flash it across a power supply to see if it spins up.
Phil01
06-04-2018, 02:44 AM #4
06-04-2018, 10:25 AM
Yeah its arrive with pins, and a connector to bare wires
06-04-2018, 10:25 AM #5
Views 480
11-08-2020, 12:06 PM
Last Post by Chris0121
Views 806
07-10-2018, 07:44 AM
Last Post by Fire_Fox_69
Views 883
18-04-2018, 01:14 PM
Last Post by Phil01
Views 469
30-08-2016, 04:12 AM
Views 960
05-08-2016, 01:12 PM
Last Post by Bandit
