wiring info needed
wiring info needed
need some info on fitting a hks turbo timer and a apexi boost controller to the is200. i know there are a few who have fitted turbo timers and if you can offer any info on this it would be great
is there any way to fit it using the factory alarm? if not what is the best alarm to get and how hard is it to remove the factory alarm and fit the new one, are there any plug and play alarms out there for the is200.
they can be wired into the standard car alarm, downside i belive is it draws from the battery rather than the alternator and thus it drains the battery very quick.
i will have a look through my files see what i can find on the wiring
Rabs i have a way to stop it doing that, will dig it out
this is the one i will be fitting
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...K:MEWNX:IT
ok still need a little help with this, i have 3+4 wires, 3 wires are to the ignition system are red,green,blue. these i need to know were they go. and 4 others, grey brown blue and black.
black is earth
blue is speed wire ?
brown is rmp. this goes to purple i was told.
grey is handbrake and i get this one
so if you can fill in the info i would be gratefull
