JapCarForum Cars, Cars, Cars! General Car Maintenance Question for math boffs - serp belt size
15-07-2018, 05:02 AM
So I'm going from a 2.55" pulley on my supercharger to a 2.25" pulley. The serpentine belt that currently fits great is a 6PK2515 (2515mm) belt.
My basic 'year one' maths tells me that the pulley is 0.30" smaller in diameter, but as the belt only makes contact with half of the pulley, I only need to account for 0.15" difference which is 3.8mm.
Now, the question is if I deduct 3.8mm from the 2151mm belt will that be correct, or do i really need to deduct 7.6mm from the belt length to account for the fact that I need to reduce the circumference by 3.8mm?
Or am I speaking utter twoddle. Someone help!!
15-07-2018, 05:02 AM #1
15-07-2018, 05:53 AM
You'll have to keep the 7.6mm belt I think, but what do I know, I only got a B in maths yesterday Smile
15-07-2018, 05:53 AM #2
15-07-2018, 06:01 AM
Dark Samurai You'll have to keep the 7.6mm belt I think, but what do I know, I only got a B in maths yesterday Smile
7.6mm belt is a bit small Wink Back to school for you.
15-07-2018, 06:01 AM #3
15-07-2018, 06:08 AM
The one that's the 7.6mm you're talking about, not 3.8!!!!!!!!!!!!!!!!!!!!!!!!
15-07-2018, 06:08 AM #4
Don't take this as gospel, but it makes sense in my head...
You need to work out the circumference of the part of the pulley that the belt will sit on for the old and new pulleys...
Old Pulley Circumference = a
New Pulley Circumference = b
Then half them both, so now you have a/2 and b/2
Then do (a/2)-(b/2) which will tell you how much shorter the belt needs to be :thumbup:
15-07-2018, 06:08 AM #5
15-07-2018, 06:57 AM
So, if the belt makes contact with exactly half of the pulley
a = 64mm (2.55")
b = 57mm (2.25")
a/2 = 32mm
b/2 = 28.5mm
32-28.5 = 3.5mm
That right?
If so, the current belt might work ok if it only needs to be 3.5mm shorter.
15-07-2018, 06:57 AM #6
a = 64mm (2.55")
b = 57mm (2.25")
a/2 = 32mm
b/2 = 28.5mm
32-28.5 = 3.5mm
That right?
15-07-2018, 07:34 AM
Looks right to me, specially as the figure you had before was 3.8 so it's all in the right area :biggrin:
EDIT: And as you rightly said that's assuming the belt is in contact with exactly half the pulley
Edited 26-08-2011, 05:09 PM by sprinter2012.
15-07-2018, 07:34 AM #7
D.F!ANT
17-07-2018, 09:55 AM
:confused1: didn't/couldn't the suppliers provide you with the necessary length?
if it were me, i'd cut the old belt, fit it and measure the gap to get a rough idea, (maybe with a strange assortment of clamps to keep it taught), And then compare that to the Math!
D.F!ANT
17-07-2018, 09:55 AM #8
Mikey
19-07-2018, 05:33 AM
or to save the old belt use a bit of string/shoelace/washing line, anything long enough
Mikey
19-07-2018, 05:33 AM #9
19-07-2018, 05:43 AM
I think the problem with using string/cutting belt is that its going to be quite hard to get the size right when you're going to be fighting with the belt tensioner.
I may just have to buy a few belts _around_ the size I think I'll need and see if I can get the shop I buy them from to agree to me returning the ones that I don't use.
19-07-2018, 05:43 AM #10
Views 588
10-05-2020, 10:47 AM
Last Post by Fry-Up
Views 621
05-08-2019, 07:12 AM
Last Post by Shavnh
Views 1,986
29-11-2018, 10:32 AM
Last Post by IanS200
Views 907
18-09-2018, 02:39 PM
Last Post by VINNY867
Views 891
29-07-2018, 02:35 AM
Views 842
28-06-2018, 01:02 AM
Last Post by Stoney
Replies 24
Views 1,605
27-03-2017, 10:37 PM
Views 1,085
11-03-2017, 05:21 AM
Last Post by Fozzy
