JapCarForum Car Manufacturers Nissan Workshop - Submit Your Tip! Nissan 350z Alarm/remote Start wiring 2006
22-01-2019, 05:27 AM
WIRE COLOR LOCATION POL.
Battery 1 White/Blue Ignition Harness Positive
Ignition 1 Black/Red Ignition Harness Positive
Starter 1 White/Red Ignition Harness Positive
Starter 2 White/Green Ignition Harness Positive
Accessory 1 White/Black Ignition Harness Positive
Parklights Red/Blue Parking Light Switch Positive
Brake Lights Pink/Blue Driver's Kick Panel Positive
Horn Green/Black Ignition Harness Negative
Tach Yellow/Red At Ignition Coil.
Lock Red In Driver Door Negative
Unlock Lt.Blue In Driver Door Negative
Trunk Purple Driver's Kick Panel Positive
OEM Hood Switch Lt.Green/Black Hood Pin Switch Negative
Disarm Lt.Blue In Driver Door Negative
Rearming Arm With Lock
Trunk Disarm Lt.Blue Driver's Kick Panel Negative
Trunk Pin Red/White (1) At BCM Module (1) Negative
Door Pin FL White At BCM Module (1) Negative
Door Pin FR PinkAt BCM Module (1) Negative
Comments :
Note: This car is equipped with a Transponder that need to be bypass.(You can't program another key DEALER ONLY.)
(1) BCM is located in driver's kick panel below the Fuse box.
(2) Trunk also a Pink (-) in a Brown plug at the BCM in the Drver's kick panel below the fuse box.
22-01-2019, 05:27 AM #1
Comments :
Views 264
11-09-2023, 11:15 AM
Views 406
11-09-2023, 11:04 AM
Views 176
11-09-2023, 10:58 AM
Views 206
11-09-2023, 10:57 AM
Views 172
11-09-2023, 10:55 AM
Views 307
18-01-2023, 06:26 AM
Views 246
18-01-2023, 06:24 AM
Views 248
18-01-2023, 06:20 AM
Views 207
18-01-2023, 06:18 AM
