Pages (132): Previous 198 99 100 101 102132 Next
12-03-2017, 07:45 AM
toxo Right, you're on. Are you booked in for any particular time of day?
Yep, 1:30pm
12-03-2017, 07:45 AM #991
Yep, 1:30pm
14-03-2017, 11:39 PM
The other day I went to check the torque on my wheel nuts, to check they were tight enough. Unfortunately, I found that one of the wheel nuts is broken. It's an aluminium "tuner" nut, the type you need an allen key-type of adapter to use. So the problem is that it is split and trynig the adapter just makes it open up more.
Going over to WIM this afternoon for a geo check-up/tweak (after lowering), so I'm hoping Tony and the boys might be able to help get the broken wheel nut off - e.g. with one of those tools for removing locking wheel nuts where the "key" has been lost - that's as long as there's enough clearance though, the nut is recessed inside the wheel. Fingers crossed !
14-03-2017, 11:39 PM #992
14-03-2017, 11:49 PM
ooo rotten luck mate hopefully Tony and his magic will get it out
14-03-2017, 11:49 PM #993
14-03-2017, 11:53 PM
I've got a really vicious set of locking wheel nut removers Wink Kinda required when you import a car with locking nuts and no key!
Mind you if that's the only thing that's gone wrong after the amount of work you've had done it's pretty good! I have a broken wheel nut at the moment as well, been driving around with 4 on one wheel for a few months... nice shiny new Rays ones on order come payday.
14-03-2017, 11:53 PM #994
14-03-2017, 11:56 PM
Luckily I do have a few spare wheel nuts, because I got a set of 20 (5 for each wheel), and I've got locking wheel nuts too, i.e. I've got 5 spare.
14-03-2017, 11:56 PM #995
15-03-2017, 02:19 AM
steviewevie Yep, 1:30pm
Done. See you there :thumbup1:
15-03-2017, 02:19 AM #996
15-03-2017, 02:23 AM
toxo Done. See you there :thumbup1:
Cool Big Grin Are you on after me then ?
15-03-2017, 02:23 AM #997
15-03-2017, 02:24 AM
Yeah I guess so. Charlie just said "come down with Steve"
15-03-2017, 02:24 AM #998
15-03-2017, 10:18 AM
It went well. As suspected, my geo needed tweaking due to the car being further lowered. Only a slight adjustment was needed at the front, but more at the rear since the rear had been lowered more than the front. The rear camber has now pretty much ran out of adjustment - it will hopefully be fine how it's been set though, even though it's slightly outside of the normal range.
An unexpected bonus was being able to see the underside of my car up on the ramp. I noticed one piece of work that Charlesworth had done that I wasn't even aware of, and another piece that I had known about but had forgotten lol. So I took lots of pics. Will post those extra bits up soon. Here are some of the general geo pics :
[Image: IMG_0319.jpg]
[Image: IMG_0312.jpg]
[Image: IMG_0306.jpg]
[Image: IMG_0298.jpg]
[Image: IMG_0321.jpg]
[Image: IMG_0313.jpg]
[Image: IMG_0320.jpg]
15-03-2017, 10:18 AM #999
15-03-2017, 10:21 AM
Not so good news on the wheel nut. Here's the offending item :
[Image: IMG_0329.jpg]
One of the Black Boots guys (WIM's sister company, who deal with tyres/wheels) had a look at this. There were two main options, the first to try hammering on an over-sized socket (one of the usual ways of trying to remove a locking wheel nut that you've lost the key for) - that one might work, but there was risk of damaging the wheel, and also risk of the nut breaking up and leaving part behind. It might have been straightforward, or it also could have turned into a nightmare.
The method I'm going to try is to find someone to weld something onto the broken nut, and then remove it that way. Trouble is the nuts are aluminium, so I need to find someone who does the more specialised aluminium welding. I will have to make some phone calls.
15-03-2017, 10:21 AM #1,000
Views 6,087
09-04-2024, 01:09 AM
Views 1,568
06-04-2024, 05:57 PM
Views 1,833
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 111,763
25-03-2024, 02:10 AM
Views 10,646
23-03-2024, 03:45 PM
Views 23,320
18-02-2024, 11:42 PM
Views 77,434
08-02-2024, 01:53 AM
Views 502
18-12-2023, 02:55 AM
Views 1,667
08-10-2023, 03:59 AM
Views 3,471
04-10-2023, 03:52 PM
