Pages (132): Previous 199 100 101 102 103132 Next
15-03-2017, 10:31 AM
The Subaru garage I went to when I had a Legacy had a wheel nut that wound on to the locking nut and cut into it, then turn the nut the way to undo the offending nut and it removed broken/stuck locking wheel nuts!!
15-03-2017, 10:31 AM #1,001
15-03-2017, 10:32 AM
Yeah the trouble with that is because of the way it is split, there's a risk that doing that will end up tearing the rest of that bit off, leaving an almost-impossible-bit-to-remove-but-stuck-fast bit behind !
15-03-2017, 10:32 AM #1,002
15-03-2017, 10:35 AM
Here are my "suprise" extra mods.
Firstly, a bit I didn't know they even did - new section of the exhaust between the downpipe and the cat :
[Image: IMG_0302.jpg]
And here's the bit that I had known about but had completely forgotten ! Can you spot it ?
[Image: IMG_0299.jpg]
[Image: IMG_0311.jpg]
No, not the rather obvious ARBs (which were on there already). But the stove-enamelled sump ! Complete with oil temp sensor going into the sump plug.
15-03-2017, 10:35 AM #1,003
15-03-2017, 10:44 AM
Well if you are welding it up, you better make sure your wheel is protected before you start and it would also be a good idea to try and remove some of the paint / coating on the wheel nut.
15-03-2017, 10:44 AM #1,004
15-03-2017, 11:13 AM
2tongues The Subaru garage I went to when I had a Legacy had a wheel nut that wound on to the locking nut and cut into it, then turn the nut the way to undo the offending nut and it removed broken/stuck locking wheel nuts!!
Those are the ones I've got, they have an inverse thread so you do them up in the direction you would normally undo a nut, as you do that they bite down onto the wheelnut and undo it. They are great and make a mockery of most locking wheel nuts (except the really well designed ones).
15-03-2017, 11:13 AM #1,005
15-03-2017, 11:21 AM
Screwfix do a set of locking wheel nut extractors? CLICK ME? not sure if it would be worth seeing if they will do the job mate? probably need to measure the outside of the broken nut to see if they would fit over it?
15-03-2017, 11:21 AM #1,006
15-03-2017, 11:44 AM
steviewevie Luckily I do have a few spare wheel nuts, because I got a set of 20 (5 for each wheel), and I've got locking wheel nuts too, i.e. I've got 5 spare.
5 spare ay! surely 4 or you'll be a nut short lol
looks a tidy bit of exhaust under the car mate, nice job
15-03-2017, 11:44 AM #1,007
15-03-2017, 12:03 PM
looking very nice mate
15-03-2017, 12:03 PM #1,008
17-03-2017, 07:11 AM
Good photos mate.
17-03-2017, 07:11 AM #1,009
Good photos mate.
17-03-2017, 09:44 AM
Marsdendean Cut your wheel down like that other post from a different forum. I have cordless 18V respricating saw!
The car still OK steve?
You could also roll the arches with a metal post like that youtube video :Chair:
17-03-2017, 09:44 AM #1,010
Views 6,065
09-04-2024, 01:09 AM
Views 1,560
06-04-2024, 05:57 PM
Views 1,829
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 111,748
25-03-2024, 02:10 AM
Views 10,629
23-03-2024, 03:45 PM
Views 23,307
18-02-2024, 11:42 PM
Views 77,369
08-02-2024, 01:53 AM
Views 502
18-12-2023, 02:55 AM
Views 1,666
08-10-2023, 03:59 AM
Views 3,461
04-10-2023, 03:52 PM
