Pages (132): Previous 1100 101 102 103 104132 Next
17-03-2017, 10:39 AM
2tongues You could also roll the arches with a metal post like that youtube video :Chair:
That method works perfectly well I'll have you know Tongue And it's scaffolding pole...
17-03-2017, 10:39 AM #1,011
17-03-2017, 11:50 AM
When I was asking bodyshops if they could roll mine I was offered the scaffolding pole method, but I told them to F off and said its a Lexus and not a poxy Nova
17-03-2017, 11:50 AM #1,012
17-03-2017, 10:08 PM
The car is still very good thanks. Dean - that's the kind of nightmare scenario that I could end up with in the worst case, I hope it doesn't come to that ! Confusedcared:
I checked my fuel consumption and I'm getting about 29mpg. Which isn't bad, I think.
There is a bit of lumpiness in how the car runs when it's on a very light throttle between 2000 and 3000 rpm, I'm not sure if this is a mapping thing.
Still need to sort the gauge pod, I haven't made any progress on that yet.
I've got a lot more used to the lightweight flywheel. I think it doesn't help that I've changed the clutch, which now has a different biting point (i.e. both the way the clutch acts and the flywheel acts are different now), and I've stalled it a *lot* less recently.
Don't think I need any arch rolling guys thanks, I'm quite happy with my Chicanes ! :biggrin:
17-03-2017, 10:08 PM #1,013
17-03-2017, 11:52 PM
Forgot to add - it's dyno day today ! :biggrin:
Off to Surrey Rolling Road later, dyno graphs to follow ...
17-03-2017, 11:52 PM #1,014
18-03-2017, 12:41 AM
good luck steve Smile Hope john makes it
18-03-2017, 12:41 AM #1,015
18-03-2017, 01:01 AM
steviewevie Forgot to add - it's dyno day today ! :biggrin:
looking forward to the graphs Stevie
18-03-2017, 01:01 AM #1,016
russelllinn
18-03-2017, 01:22 AM
Good to hear things are going well Steve and you're getting used to the clutch and flywheel, it would be a major change reallly in one hit but I am sure you're getting loads of practice in Smile look forward to the results :thumbup1:
[Image: AliceTrack-1.jpg]
Have a look at my Scooby project thread here
My garage
Subaru
russelllinn
18-03-2017, 01:22 AM #1,017
My garage
Subaru
18-03-2017, 02:00 AM
Oh, and it hasn't used any oil either yet :thumbup: (I check it regularly)
Need to sort out the engine check light too, which as I described earlier, is just due to a spurious code about an O2 sensor - I'm going to be replacing that with an O2 simulator.
18-03-2017, 02:00 AM #1,018
edeath
18-03-2017, 03:41 AM
Good luck on the Dyno run. Hope the mappped figure is accurate Smile. How come the O2 sensor is coming up? Should only show if the CAT is not working/present.
edeath
18-03-2017, 03:41 AM #1,019
LEX11S
18-03-2017, 06:29 AM
Hi mate good luck with the dyno run do you know the code its coming up with?
mine puts up po135 which is o2 sensor heater circuit
LEX11S
18-03-2017, 06:29 AM #1,020
Views 6,065
09-04-2024, 01:09 AM
Views 1,560
06-04-2024, 05:57 PM
Views 1,829
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 111,748
25-03-2024, 02:10 AM
Views 10,629
23-03-2024, 03:45 PM
Views 23,307
18-02-2024, 11:42 PM
Views 77,369
08-02-2024, 01:53 AM
Views 502
18-12-2023, 02:55 AM
Views 1,666
08-10-2023, 03:59 AM
Views 3,461
04-10-2023, 03:52 PM
