Pages (132): Previous 1101 102 103 104 105132 Next
18-03-2017, 06:36 AM
The dyno went well, will post up the graphs/figures shortly.
The code I have been getting is P0420, which is saying it thinks the cat is not working properly. But this only comes up occasionally. The cat is definitely fine since Charlesworth put it on their MoT emissions machine, and it flew through that. Charlesworth reckons the sensor just can't cope with the differing amount of gases that it's seeing now.
Today I had some other codes come up on the way to the dyno, which was slightly worrying. But the codes were P0171 and P0174, which is a warning about the AFR being too lean. I've got a gauge to monitor this myself of course, and I think the codes possibly came up because I was experimenting with the throttle to reproduce the problem I have with it going a bit lumpy on very light throttle - the fuelling was certainly fine on the dyno.
LEX11S, P0135 is the O2 sensor heater circuit as you say, I wonder if you have a real sensor problem there ? The heater is needed to heat the sensor up so that it can detect the AFR properly.
18-03-2017, 06:36 AM #1,021
18-03-2017, 07:14 AM
Here we go. Flywheel figures are 257.9 bhp and 247 lb/ft torque. At the wheels this is 211.3 bhp and 201 lb/ft.
I'm well-chuffed with this. It matches well to Noble's figures (Charlie from SRR was expecting less, because he thought that Noble's dyno typically read a bit higher than theirs - though maybe with putting 1000 miles on the engine it might have developed a bit more bhp ?).
Also, I'm very happy that the car now has significantly more power at the wheels (211 bhp) than it did at the flywheel when stock (153 bhp).
The graphs also show my stock figures (since it's been dyno's at SRR when stock), which provide a very interesting comparison. As you would expect, there is actually slightly less power low down in the rev range, due to the turbo acting as a restrictor. But at 3550rpm this crosses over, and it starts to develop a lot more power (spot the big gap between the red and black solid lines on the first graph !).
On all of the graphs, the red lines are the stock figures (from a previous dyno session), and the black ones are the current figures.
On this first graph, the solid lines are the power (bhp, axis on the left), and the dotted lines are the fuelling (axis on the right). Remember that as the fuelling line dips down (smaller number AFR), this indicates more fuel is going in (richer mixture, hence less air to fuel).
[Image: Dyno1.jpg]
This second graph shows power (left-hand axis, black line for current power) and also boost (right-hand axis, black dotted line), which is peaking at approx 0.9 bar and holding at 0.8 bar (these are the monitored figures and the actual boost is probably a bit higher, e.g. the manual boost controller is set to 1.0 bar).
[Image: Dyno2.jpg]
The next graph shows torque on the right-hand axis, as the dotted lines (stock and current).
[Image: Dyno3.jpg]
Finally we have the figures measured at the wheels (the previous figures are calculated from these for the flywheel, using measured transmission losses).
[Image: Dyno4.jpg]
18-03-2017, 07:14 AM #1,022
[Image: Dyno1.jpg]
[Image: Dyno2.jpg]
[Image: Dyno3.jpg]
[Image: Dyno4.jpg]
18-03-2017, 07:27 AM
good news steve Smile did John make it in the end?
18-03-2017, 07:27 AM #1,023
18-03-2017, 07:28 AM
Yes, John made it, hope he didn't break too many speed limits to get there ! I'll leave him to report on his run (and also his sorting out of his CV joint problems).
18-03-2017, 07:28 AM #1,024
18-03-2017, 07:56 AM
I well pleased you are happy with the car mate , good for you :thumbup1::thumbup1:
18-03-2017, 07:56 AM #1,025
18-03-2017, 08:30 AM
Lots of interesting graphs mate. Very smooth power delivery:thumbup1:
18-03-2017, 08:30 AM #1,026
18-03-2017, 09:15 AM
Yeah good point Phil, I hadn't really had a chance to notice that the graphs do show pretty clear how well it pulls - the turbo pulls very smoothly indeed, it doesn't come in with a big bang after doing nothing for ages - from 3500rpm it just pulls and pulls :thumbup:
18-03-2017, 09:15 AM #1,027
18-03-2017, 09:27 AM
Couple of pics of my car on the dyno (at Surrey Rolling Road) :
[Image: IMG_0332.jpg]
[Image: IMG_0335.jpg]
18-03-2017, 09:27 AM #1,028
lexynik
Unregistered
18-03-2017, 10:45 AM
well done-in reality on the power graph even where you say you have lost a little bit due to the turbo acting as a blocker it really is a tiny bit and the power is delivered in the same smooth way as stock until it crosses over and never looks back - as you aimed for it looks very drivable - if it was me id be very pleased with myself in your shoes,impressive
lexynik
18-03-2017, 10:45 AM #1,029
18-03-2017, 10:48 AM
So Steve can I have a go when we meet next ???????????????
18-03-2017, 10:48 AM #1,030
Views 6,087
09-04-2024, 01:09 AM
Views 1,568
06-04-2024, 05:57 PM
Views 1,833
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 111,762
25-03-2024, 02:10 AM
Views 10,646
23-03-2024, 03:45 PM
Views 23,320
18-02-2024, 11:42 PM
Views 77,424
08-02-2024, 01:53 AM
Views 502
18-12-2023, 02:55 AM
Views 1,667
08-10-2023, 03:59 AM
Views 3,471
04-10-2023, 03:52 PM
