Pages (132): Previous 1107 108 109 110 111132 Next
30-03-2017, 06:08 AM
They will be 23209-70120 Smile
Toyota use lots of 210cc injectors, N/A MK3 supras, some 4AGE engined cars for example.
BGB for your car states when testing fuel injectors:
Quote:Injection volume:
47-58cm3 (2.9 - 3.6 cu in.) per 15 seconds
Working on the basis that 47-58cm3 has a tolerance of say +/-5, I used 52cm3 as the size. Multiply that by 4 to get 60 seconds and you have cc/min (cm3 and cc same thing). That makes 208. Close enough to 210 Smile
30-03-2017, 06:08 AM #1,081
30-03-2017, 06:11 AM
toxo They will be 23209-70120 Smile
Yep, that's the part number. So are they definitely 210cc then ? That's brilliant, that would let the map use the injector sizes of (old) 210 vs (new) 550, and the e-Manage can work out the fuelling itself, rather than having to manually input it all. Though of course the fuelling still needs setting up for the turbo.
30-03-2017, 06:11 AM #1,082
30-03-2017, 06:13 AM
toxo BGB for your car states when testing fuel injectors:
Ah, the penny has just dropped on where you got this from. That's great, thanks :thumbup:
30-03-2017, 06:13 AM #1,083
Not definitely. That part number is IS200 specific more or less, and like I said I only sorta worked it out from the testing parameters in the BGB. It does sound right, though.
Googling that part number is no help either!
30-03-2017, 06:13 AM #1,084
30-03-2017, 06:14 AM
Yeah sorry, I guess Lexusheads don't refer to the workshop manuals as BGBs? Smile They are Big Green Books where I come from :lol:
30-03-2017, 06:14 AM #1,085
toxo Working on the basis that 47-58cm3 has a tolerance of say +/-5, I used 52cm3 as the size. Multiply that by 4 to get 60 seconds and you have cc/min (cm3 and cc same thing). That makes 208. Close enough to 210 Smile
Or is you use 52.5, which is exactly half-way between 47 and 58, then you get 210 exactly :thumbup1:
30-03-2017, 06:14 AM #1,086
30-03-2017, 06:16 AM
toxo Googling that part number is no help either!
I was going to see if there was an actual physical part number on the injector, e.g. a Denso part number or whatever.
toxo Yeah sorry, I guess Lexusheads don't refer to the workshop manuals as BGBs? Smile They are Big Green Books where I come from :lol:
I hadn't figured out what BGB stood for, though I knew what you meant. Thanks for the explanation though :lol:
30-03-2017, 06:16 AM #1,087
Huh Why didn't I think of that
30-03-2017, 06:16 AM #1,088
01-04-2017, 11:53 PM
I'm still thinking about what to do here. But I'm leaning towards the suggested re-map, using the different way of doing the fuelling (by telling the e-Manage the original injector size and the new injector size and letting it calculate things as a base), plus getting rid of the existing O2 sensor (standard cars have two sensors in the manifold, mine just has one now).
I have clarified things a bit, and the theory is that if we get rid of the sensor, the stock ECU will just revert to its pre-programmed parameters of how to fuel the car, and not try and correct what's going on (because it will be fed a signal that just tells it everything is fine). The e-Manage then can do its bit on the fuelling and won't have the stock ECU trying to override it. This will probably help the slight lumpiness, and *might* fix the very intermittent problem I had with the boost cut.
The lumpiness is a very very minor problem, by the way (and is probably a consequence of the larger injectors). A lot of people may well not be worried about it (or even notice it ?) at all, it's mainly me just wanting the car to run as "Lexus" as possible when off boost.
01-04-2017, 11:53 PM #1,089
edeath
02-04-2017, 12:14 AM
Is there not a risk removing the Lambdas? If something starts to go wrong and you miss it on the AFR meter then there will be no way for either ECU to tell and try and sort it out?
Though maybe I have missed the point here lol
edeath
02-04-2017, 12:14 AM #1,090
Views 6,094
09-04-2024, 01:09 AM
Views 1,568
06-04-2024, 05:57 PM
Views 1,842
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 111,777
25-03-2024, 02:10 AM
Views 10,653
23-03-2024, 03:45 PM
Views 23,327
18-02-2024, 11:42 PM
Views 77,486
08-02-2024, 01:53 AM
Views 502
18-12-2023, 02:55 AM
Views 1,667
08-10-2023, 03:59 AM
Views 3,472
04-10-2023, 03:52 PM
