Pages (132): Previous 1108 109 110 111 112132 Next
02-04-2018, 06:04 AM
On Steve's setup the e-manage has an LC-1 wideband lambda sensor attached to it, so the stock ECU doesn't need to do any AFR management. It just needs to sit there and behave! I think.
02-04-2018, 06:04 AM #1,091
02-04-2018, 06:10 AM
The stock ECU will just use its pre-programmed map. If something went really wrong on a stock setup, the ECU probably wouldn't be able to compensate enough anyway, and you wouldn't notice it with no AFR gauge.
I do have the AFR gauge to keep an eye on things. Currently my LC-1/wideband lambda isn't connected to the e-Manage, though we can always change that.
Bear in mind that in the days before O2 sensors, this is the way all cars used to run anyway !
02-04-2018, 06:10 AM #1,092
02-04-2018, 06:15 AM
Ah I was under the impression that the wideband was connected to more than just the AFR gauge... my mistake! Don't even know of the e-manage can run wideband actually.
The days before O2 sensors... right, the 80s! Smile Not sure I'd feel too happy running EFI with no O2 sensor to be perfectly honest, especially not on a blown engine.
Edit: A quick google suggests that it's as simple as connecting the white wire from the e-manage AFR harness to the white wire from the LC-1 and then configuring the sensor in the e-manage itself (you have to configure a voltage range, i.e. 10-22.5 or suchlike). I reckon putting O2 simulators on the stock ECU and then getting the e-manage to control AFR should be a pretty good solution.
Edited 14-05-2010, 10:08 AM by toxo.
02-04-2018, 06:15 AM #1,093
02-04-2018, 06:31 AM
Yeah you can connect the LC-1 to the e-Manage. I'm not sure if the e-Manage can use this to adjust the fuelling while it's running though, as opposed to just coming up with a base map ? I'll take a look at the manual.
02-04-2018, 06:31 AM #1,094
Fozzy
02-04-2018, 06:54 AM
If you connect the white wire from the LC-1 it will run as a narrow band sensor for the e-manage to understand. As to whether it will affect the map is down to how it has been set up. The e-manage has the capability to run as a closed loop system and monitor the AFR as per the stock ecu.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
02-04-2018, 06:54 AM #1,095
02-04-2018, 08:10 AM
Cool, thanks Pete :biggrin:
02-04-2018, 08:10 AM #1,096
08-04-2018, 11:17 AM
Just took the car for an MoT. It sailed through, the only advisory was for my engine check light being on, which is just the code for the O2 sensor after the cat, which I already knew about.
So that's great ! :thumbup:
08-04-2018, 11:17 AM #1,097
08-04-2018, 11:22 AM
nice one steve glad to hear its all running smoothly :biggrin:
08-04-2018, 11:22 AM #1,098
08-04-2018, 12:01 PM
Awesome news steve
08-04-2018, 12:01 PM #1,099
Awesome news steve
08-04-2018, 12:02 PM
That is great news Stevie.
08-04-2018, 12:02 PM #1,100
 5 Guest(s)
 5 Guest(s)
Views 13,991
Views 3,845
Views 4,675
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 168,089
Views 21,378
Views 44,828
Views 134,682
Views 1,267
Views 3,567
Views 6,415
